Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
What does the inside of the Maxtor External Drive look like?
Does the hard drive inside my Maxtor External Hard Drive look like a regular internal Hard Drive? I am getting a Code 10 error for my Maxtor External hard drive, and I have been reading that I can remove the hard drive from the casing and then install it internally in my computer. However, I am a little uncomfortable with opening up the back of my computer and installing this hard drive in it. However, I saw a product at Best Buy called the ThermalTake Dual Bay Docking Station for most Internal SATA hard drives, where you can add 2 SATA internal hard drives to your computer externally through a USB port. And, I wanted to know if I removed my hard drive from the Maxtor External hard drive casing, would I be able to plug the hard drive into the ThermalTake Dual Bay Docking Station for most SATA Internal Hard Drives to retrieve my information? Thank you.
  • 615 Answers
Hi, Each driver got its own setting, saying that your hard drive on the inside of your computer is setup to be XYZ of your reading sequence of your system, when you take it out and replace it as you mentioned it may not work as it still reading the sequence but cannot access it.
Recommendations, if you need to save your data from the external then you back up all data on the one inside your computer, then you backup all data on the external drive, now remove all covers from the external driver and do same with the internal, remember and see where is the pins locations on the front and back. Move the pins exactly on the external one to be same as the one that was internally, after that the external disk took the place of the old internal and now acting as new one. The reasons for the pins movements is it allows the OS (operating System) to know the order of the disk if it is #1 or 2 or 3 etc. and each pin location is a number.
If you need more detailed information you can close this post and contact me using my same ID to hotmail and that is free of charge. The site does not allows lots of space to be used so we csan use IM, etc.
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Posted on Sep 29, 2009
I have the maxtor hard drive, and i want to save alot of my photos on the hard drive but NOT on the computer (but be able to access them everytime i plug in my external hard drive. please help!
The only way you can access that Hard dive on a different computer is to make it a slave.
Look at the jumpers on the rear and set it to either SL or CS (cable select)
I may have misunderstood your question because first you are saying a hard drive ( like an internal Hard drive) then you are saying external hard drive ????
Feb 22, 2011 | Maxtor Hard Drive
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
I have just been given a Maxtor 750gb separate hard drive but it has no power adaptor. Would i be able to use an adaptor from my 500gb Maxtor separate hard drive or will i have to purchase a new power...
By SEPARATE I am taking that to mean an external drive and not an internal mounted drive. If IT IS external the same power supply should work fine as the drive motors are the same in both models. IF IT IS Internal then the question is whether your power supply is molex or ATA.
Jun 06, 2010 | Maxtor Hard Drive
External maxtor isn't recognized on XP
Since you have important files on this drive, do not waste a lot of time with troubleshooting. If your drive is about to go out, you can put it over the edge that way and kill it.
Just to be sure, I would plug the drive into 1 other computer just to make sure. If you get the same thing, the problem is definently with the Hard Drive.
If this is the situation, I would take off the outer case to reveal the regular hard drive inside. You can hook this hard drive up to your computer as a slave and copy the files off. If your computer will not read the drive as a slave, and you have double checked the jumper settings and cable position.....you can try a program like "Get Data Back" to try and recover data off the bad/corrupted hard drive.
Jun 02, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
My external hard drive is 300g,i formatted my internal hard drive and found that my external drive was also formatted and was only 3g.could someone help me please that's a lot of space lost
do you have a recovery disk for the internal hard drive? this is the disk that came with pc.your internal HD is important this have been wiped (you have no OS) . get your internal back in order........do you have a receipt that says you purchased a 300gb (not 3gb) take it back get your money or the right external... once you are able to use the pc double check the external hard drive
Feb 16, 2010 | Maxtor OneTouch II 300 GB Hard Drive
My computer will not recognize my external hard drive
the external hard drive's motherboard is burnt take it apart (this will be a little hard but it will come apart) after you take apart u will see it is just an internal hard drive in a case so either...
1) put it inside your computer as an internal or..
2) buy a new external hard drive case (that will have a new hdd motherboard in it)
after you install it either way your computer will reconize the hd and WORK i done this just yesterday.
Nov 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My computer cannot dectect my maxtor one touch III 320GB
well, 2 options, your hard drive is not working in that case, just get a internal hard drive which is serial and open the case for the maxtor and plug the drive inside the case. its cheaper to buy the inter hard drive, then to replace the external hard drive.
Oct 29, 2009 | Maxtor OneTouch III 300 GB Hard Drive
Formatting
Inside the iMac or as an external drive? If internal: Use the OSX Installation disk
Sep 29, 2008 | Maxtor Hard Drive
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
73 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
