Question about Garden
Engine runs and shaft spins until pressure put to it then shaft stops spinning but engine will continue to run
catriver
  • 878 Answers
SOURCE: drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Posted on Nov 05, 2006
SOURCE: SPIN CYCLE
Front load Neptune model
Posted on Nov 25, 2007
  • 96 Answers
SOURCE: Cycle runs normally but the washer does not stop after spin
I don't know specifically about your machine but I think the problem is with the door lock. Again, on most machines with a shakeout it can go on and on until the door unlocks. Does your machine have a door UNLOCKING solenoid or does the door lock just lose power at the end of the cycle. It may be that you just have a very weak solenoid to unlock the door.
Posted on Feb 19, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag won't agitate during wash
sounds like you have a broken sety fo brake pads, just replaced a set today for same reason, open the lower acess panel and with a flashlight look into the bottom , your lookin for brake pads( theyre probably broken and laying under unit.)
Posted on Apr 29, 2008
  • 338 Answers
SOURCE: Middle arm stopped spinning
you may be exactly right. I always start with something simple. spin the spray arm to make sure it goes all the way around with out touching anything. next is the hard partyou would have to take the motor apart and any filters you see and clean out all the debris.
Posted on Nov 28, 2008
My husband was mowing with an Exmark Quest riding mower and ran over an extension cord. It stalled and won't start again.
The flywheel is locked to the crankshaft with a aluminium key. If the engine is abruptly stopped this soft aluminium key will shear off and let the flywheel turn.The shaft quits turning and the flywheel don't. This is to avoid breaking the crankshaft. When the flywheel turns or spins on the crankshaft it puts the spark timing out of time and will not run, it might backfire or spin and stop or just spin over.
Jul 17, 2016 | Garden
Prop spins when out of water but when i put it in the water it slows down to a slow creep
yes very common, have you hit a rock as some stage or maybe it is wearing out but as soon as some pressure goes on the prop the shaft will spin normally but the prop is now no longer held to the shaft correctly hence your problem. Check it by marking the prop and shaft with a straight line then put it in the water, take out and check your mark they probably wont line up anymore. Solution...get a new prop. I have a different way to get these fixed but it is not recommended I drill a self tapping screw into my props just until it hits the drive shaft then stop just enough pressure to keep to stuck to the drive shaft
Apr 09, 2014 | Minn Kota Riptide St Saltwater 55 Bow...
Drill runs until pressure is applied to the bit. then the motor cotinues to run but the chuck stops spinning.
It sounds like the gears themself are stripped. On the inside of the drill right behind the head is a gear that turns the head itself. When that gear is stripped the head will spin sometimes withou pressure but when pressure is applied the head will not spin
Jun 16, 2012 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Homelite trimlite engine runs but head does not spin
Sounds like the inner flex shaft has broken, slacken the tube up at the engine and pull the tube and shaft assemly away, pull the inner shaft out and inspect
Apr 14, 2012 | Homelite Garden
Hi i have a echo weed eater. It starts with only a couple of pulls and the runs great and sounds great. when i have the head up in the air it spins rather quickly but when i hit grass the head starts to...
check the cable that runs through the shaft from engine to head, it may be brocken or striped but when theres no pressure on the head it spins ok
Jul 24, 2011 | Garden
My lakewood HV18 just stopped. Spinning the shaft
I think you need to buy a new fan. Unless this thing cost several hundred dollars it isn't worth rewinding and a capacitor isn't likely to cause it to stop working, the cap is for STARTING it spinning anyway and sometimes they are used to HELP it run better, but it will try to run if you spin it and since your's does nothing, more than likely the windings are gone.
Sep 09, 2009 | Lakewood HV 18-c Floor / Box Fan
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
97 TJ reverse issue
your syncronizer is going out on the reverse you need to have it looked at soon
Dec 25, 2008 | 1993 Jeep Grand Cherokee
Drain pump starts and stops prior to final spin cycle
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
