WD external HD - corupt maybe?
Whenever i plug my 400 GB external hard drive into a computer the computer recognaizes the fact its been plugged in but i cant accsess it :( can anyone help me?
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
NB !
! ! DO NOT PLACE A HARD DRIVE IN A FREEZER ! !
THIS IS VERY OLD ADVICE FOR VERY OLD TYPES OF HARD DRIVES THAT ARE NO LONGER EVEN MADE. A FREEZER CAN CAUSE MORE DAMAGE.
If I keep collecting "frozen hard drives" at the rate i do i will soon have enough to build a small house
Posted on Sep 29, 2009
  • 6,831 Answers
Hello
Try the following steps and you might just fix your problem.
Go to:
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below. Right click on the drive which you want to acces and choose the option to assign new drive letter, choose a new letter and restart.
All should work fine now. Please rate this.
Best regards
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
External drive problem
This sounds like an amperage issue.
The elements drive is made to be highly portable and comes without an external power supply. As such you need to connect the drive to your PC using both USB connections on the Y-Cable it came with. Failure to do so will leave the drive with less amperage than it needs to run at full RPMs.
Everytime you try to read or write to the drive, the loss of amperage will cause it to reset. This may cause data loss depending on what the drive is doing.
If it did not come with a Y-Cable, stop in at your local PC store and buy one as this will solve the issue. If it did, and it is having this problem even with both USB plugs connected then it's likely there is a fauly circuit in the enclosure. Have it replaced un WD warranty if able, if not reply back and I can advise you how to swap it into a new enclosure.
Crankstart
Feb 11, 2010 | Western Digital Elements powered by WD 320...
Wd external hard drive stopped working
Sounds like you need to create a new partition, and if you find that a partition already exists, delete it and create another.
Jan 03, 2010 | Western Digital Elements powered by WD 320...
WD external HD doesn't show on vista in my computer or drive mana
You could have a virus on your computer. Do a virus scan by going to nortan's website. There is no way around the virus, the only way is to format the drive, and reload windows.
Dec 12, 2009 | Western Digital My Book Essential Edition...
When i plug in my external hard drive, the
u need to fix your external....it has a virus thats why!.....
Oct 06, 2009 | Western Digital Elements powered by WD 320...
I kicked my HD by accident, now my laptop does not recognize the Western Digital 1TB My Book external HD. I tried to plug it in from different USB ports, tried with my desktop, and my parents' desktop but...
Hello there,
There might be a disconnected wire inside your My Book, preventing it to be detected by your computer. Or maybe a broken part that needs to be resoldered. But dont worry, you harddrive is still secure.
What you need to do is to take off the hard disk inside and place it in another USB hard disk enclosure. How to do that, here is a video that could guide you.
http://www.youtube.com/watch?v=6FlySnyJ0CQ
Or if you dont have an enclosure you can place that inside another computer for it to detect it as data drive.
If you have further questions, please let me know.
Aug 29, 2009 | Western Digital My Book Essential Edition...
My computer restarts recognaizing WD external hard drive!
I suggest you check the power management on the device. You can right-click the disk in the Device Manager and see if it is allowed to be powered off, or you can check the power settings in the control panel.
Most likely it is turned off, and when it resumes, the computer somehow thinks it was not plugged before.
Jules
Apr 19, 2009 | Western Digital Passport WDXML800UE...
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
HD doesn't work on other computer
Go into my computer, right click, hit refresh and click on the hd
Jan 10, 2009 | Western Digital Passport WDXML800UE...
My WD MyBook 500GB drive is causing Windows XP to be self-retardant. (Slows)
Heres what you do.
Don't plug your external HD in while the computer is booting up. It's looking for Windows on your external hard drive. Hence the black screen.
Plug your USB or Firewire cable back in once Windows is finished booting up.
Mine does that sometime too.
Jun 13, 2008 | Western Digital My Book Essential Edition...
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
