Question about Panasonic KX-CL400 Laser Printer
It says code e-66 for service - Panasonic KX-CL400 Laser Printer
Error code 66
conflicting info
http://www.obd-codes.com/trouble_codes/gm/gm-2-digit-codes.php
66- pressure sensor or circuit air conditioning
http://www.cadillacfaq.com/faq/answers/dtccode.html
DTC 66 - Driver Air Bag Deployment Commanded
Apr 09, 2016 | Cars & Trucks
What is TSB 71-65-66 and how to fix it?
DTC 1676 [Archive] - FirebirdV6.com/CamaroV6.com Message Board
forum.camarov6.com > ... > Technical > Advanced Engine
Mar 6, 2003 - 9 posts - ‎4 authors
71-65-66 NOV 97 Engine Controls - EVAP DTC's P1665 & P1676 Added " that is from alldata as a TSB i dont know what "EVAP" is though.
Find Technical Service Bulletins for your 1998 Buick ...
tsb.govwebs.com/k-vin-v638l-lesabre-buick-1998-10199.html
Free Technical Service Bulletin and Recall Titles for 1998 Buick LeSabre V6-3.8L VIN K ..... 71-65-66, NOVEMBER 1997, Engine Controls - EVAP DTC`s P1665 ...
Trouble Code - AutoZone
www.autozone.com/.../Buick.../_/P-0996b43f8036fc4e
AutoZone... power circuit is open (check ENG EMISS fuse). Purge solenoid is damaged, or the PCM has failed. TSB 71-65-66 contains a repair procedure for this code ..
Nov 24, 2015 | 1998 Buick Century
Sim 66-10; What does The confidential data mean?
The MX-2310U offers Confidential Printing, which when used, requires users to enter a PIN code in order to print a queued document. To help protect your direct-print documents from unauthorized viewing, the MX-2310U offers encrypted PDF printing and scanning. Additionally, Secure Fax Release ensures received fax documents are held in memory until an authorized user enters a PIN code, so that compliance with healthcare regulations such as HIPAA is easier.
This data will be cleared if Sim 66-10 is enacted.
Mar 01, 2015 | Sharp MX-2310U Color Printer : 2310U
What are OBD1 engine codes 53, 66, 32 ???
Code 53 is Heated Oxygen Sensor Heater Resistance Bank 1 Sensor 1
Code 66 is Air Assisted Injector Control Circuit Or Circuit Low
Code 32 is Heated Oxygen Sensor Heater Control Circuit High Bank 1 Sensor 1
If you want to check it out yourself go to. http://www.actron.com/code_lookup.php
Jun 05, 2014 | 1995 Lincoln Town Car
Yamaha r1 error code 66
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/161-09-14-r1-mechanical-help/286089-09-r1-error-code-66-a.html
Yamaha Fault Codes
Yamaha YZFR1Y 2009 Service Manual
OEM parts for Yamaha
Yamaha YZFR1Y Owner Manual
Aug 01, 2013 | 2008 Yamaha YZF-R1
Machine says "I need service"
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
I took this from the service repair manual. Hope it helps.
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66. On some machines the pressure switch is seperated and sometimes the plastic tub for the switch gets clogged up and blowing through it will sometims clear this fault. Not sure about this particular machine, but you can try adjusting water level to see if it will work at a different level of water.
Mar 24, 2011 | Fisher and Paykel (IWL12)
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
1998 kia carnival, radio is not working, display shows ''CODE''
I have a manual for a '99 model - the one with separate radio/cassette and CD model No's;
OK55Y 66 860
OK55L 66 860
OK55D 66 860
3K55L 66 860
2K55D 66 860
3K55Y 66 860
Under "How to enter your password"
1. press power button & "Test" appears for 5 seconds, and blinks for 5 minutes. If you turn the power button off then back on again within 5 minutes "Code" blinks on the display.
2. enter password using the numbered buttons - press button 1 once to let it know it's the first digit, then press button 1 again however many times to bring up the code for the first digit. Press button 2 to let it know it's the second digit, then again however many times....etc. To enter default 1111 code, press button 1 twice,, 2 twice, 3 twice then 4 twice.
3. when all four digits entered (default is 1111) press SEL button and display should say "GOOD"
4.You get three goes, if still wrong after third attempt "HOLD" then you have to leave it for an hour
May 02, 2009 | Kia Sedona Cars & Trucks
Today's codes please anyone on ntl
00=5c-2c-26-36-cf-81-ab-66
01=9f-09-00-66-3b-d2-43-8b
Feb 25, 2009 | StarTech.com StarView SV211K 2-port KVM...
Codes for ntl starview box gone 18/02/09
pleeeeeeeeeeeeeeeeeeeze!!!!!!!!!!!!!!!!!!!!!!!!!!!!! give me todays code
Feb 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Panasonic KX-CL400 Laser Printer Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
