Question about HP OfficeJet Pro k550 Printer
There's an option to reset the HP K550 via the buttons on the printer. You have to unplug the printer and press the buttons, but I don't know wich. Do you have a solution. Thank you Willy
    Scholar:
  • 67 Answers
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Sep 29, 2009
How do I reset displaylanguage to english HP C6180
You can do a reset on your printer.Unplug the power cord of the printer.Press and hold the # and 6 buttons together and then plug the power cord back into the outlet.Keep holding the 2 buttons until the display goes blank or RESET is displayed.If the printer automatically turns off, turn on the printer.The printer should start up and you will be able to select language code.
Oct 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hi, i have an HP Officejet pro k550 series printer and i dont know how to set the wireless setting, eg. IP configuration
If you printer has the optional Jetdirect print server istalled and you have a wireless router, then to configure this printer for your wireless network, please click on this link and follow my instructions.
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Jul 04, 2011 | HP OfficeJet Pro k550 Printer
Hii need to reset the hp deskjet 680c printer.i don`t know how to do this. thanks for you attention. regards.
h10032.www1.hp.com/ctg/Manual/c00256077.pdf -
Above is your user manual.
Turn off your HP DeskJet printer. Turn it back on and connect it to your computer using the USB cable.
To reset the INK Counter, see below.
Click open the "Start" menu on your computer. Click on "Control Panel," and double-click "Printer and Faxes."
Locate the icon of your HP DeskJet Printer along with its model number. Right-click this icon and click on "Properties" from the pop-up list.
Click the "Services" tab and select "Service This Device."
Select the "Estimated Ink Level" tab. Click the option "Reset Ink Level." The printer will then show a refreshed ink cartridge level for your printer.
To reset all settings and print test page. see below.
* Press and hold the Power button.
* While holding the Power button, press and release the Resume button four (4) times.
* Release the Power button. A self-test page will print.
Jun 17, 2010 | HP DeskJet 680c InkJet Printer
My machine is hp officejet pro K850
Sometimes when you unplug devices for 5 to 10 minutes the memory resets. This my help if not let me know.
Dec 14, 2009 | HP OfficeJet Pro k550 Printer
Error message 0xc18a0001 Ink system has failed. Unable to print. Refer to printer documentation.
Easy fix. I found elsewhere on this site that the solution is to RESET the printer via the following instructions from HP...
1) Unplug Printer
2) Simultaneously press and hold the HELP & OK buttons
3) Re-plug in printer, while still holding the two buttons.
That's it ! You are reset. It will take a little time for the printer to re-configure, but you'll be printing in 5 or so minutes.
Sep 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp c7280 all-in-one printer will not shut off
I'm assuming your printer power button will not shut the printer off. You can unplug the power connector from behind the printer if it won't shut off via the power button or power switch.
Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Apr 20, 2008 | Office Equipment & Supplies
Chatters
i belive that your printer needs to be resetted. Just try the reset options which are for HP 6110xi.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thank You
Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP K550 blak print failure
Hold the far button on the right down for a minute and it will move the head over for access
Jan 06, 2008 | HP OfficeJet Pro k550 Printer
HP OfficeJet Pro k550 Printer Logo
3,291 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
