Question about InFocus Proxima DP2000S Multimedia Projector
Proxima DP2000S will not power on - InFocus Proxima DP2000S Multimedia Projector
I have a proxima DP2000s when I connect to the power supply I have not power at all. Who can help me
Posted on Apr 24, 2009
Replaced bulb for a proxima c160 bulb won't strike led power button flashes red what can I do
You may have purchased an aftermarket generic lamp. The chances that the lamp is defect is about 20% with the counterfeit products....Read here for a better explanation:
I also suggest buying the original lamp as recommended by the above link. You may find yourself troubleshooting further for no reason simply by buying an aftermarket replacement.
Apr 26, 2010 | ASK Proxima C160 Multimedia Projector
Proxima LP240/250 power supply failure bypass
It's easier to repair the power supply if you're going to that length. If you have a power supply failure, and you already know the voltages, you should be able to trace the failed components. If not, let me know and I'll get you up and running again.
Dec 30, 2009 | ASK Proxima Proxima DP2000X Multimedia...
Ask Proxima will not start up
If it has no power at all or has power but fails to start, it is most likely the power supply needing to be upgraded or replaced. If you look at the projector with the top off, there should be a green wire going from the top of the main board (it is soldered to a orange cap in a group of 4) leading to the underside of the power supply. If you don't see this then your power supply is probably one that was never upgraded.
Oct 25, 2009 | ASK Proxima M2+ Multimedia Projector
ASK Proxima c170 Power Supply Failure
I really doubt you'll find a generic power supply for this unit. I can repair this power supply for you at a low cost. I repair power supplies. My ebay ID is Gtitubro
Mar 02, 2009 | ASK Proxima C170 Multimedia Projector
I'm looking for a schematic/diagram for the ASK Proxima C50. Where can I find this?
But it can be repaired. If you still have the unit in need of repair, contact me at bhodginsatplaspdotcom
Jan 25, 2009 | ASK Proxima Proxima DP2000X Multimedia...
Same problem- shuts off automatically
Clean the air filters and also check the fan is working for proper
air circulation.
May 23, 2008 | ASK Proxima Proxima DP2000S Data Video...
Need Drivers
Hi Jess
Is your PC's image splitt ?
Right click on your desktop and go to properties - then click on settings and then advanced settings.
You'll see a block with two screens on it. If only one is activated - activate the secondary screen as well.
If you are using a Notebook also try holding in the Fn ( Function ) button - just left of your spacebar and in your F-row buttons at the top there should be one with two screens on it - Differs from brand to brand of PC's.
Hope this helps you !
Mar 26, 2008 | ASK Proxima Proxima DP2000S Data Video...
Infocus In24+ driver?
I think projector is do not need driver, i see in the infocus website as long as you connect it to the computer it always display.
please see the details of your infocus here:
and also you can download updates firmware to fix some error display.
May this help, best regards, melnavz
Jan 14, 2008 | ASK Proxima Proxima DP2000S Data Video...
Rolling line
If this is seen when you are connecting to a cable box or satellite box like DirecTV through or other such device your issue is most likely a DC ground loop. Here are some suggestions:
Video Projector ground loop
1) If you have horizontal hum bars when your projector is connected to a set-top box or other equipment that are on a different circuit or are grounded causing a ground potential between the source and the projector
2) Hum bars are the result of a ground loop, usually caused by cable television that has not been properly grounded
Try this to verify:
1) Disconnect your cable television coax from the wall by unscrewing it.
2) Run your Projector and verify that you are no longer getting the lines.
If you have verified that the issue was a ground loop by testing the solution requires a DC
Ground Blocker style device similar to the below options:
1) Go to (part number 2118)
2) Purchase a DC GROUD BLOCKER & ISOLATION TRANSFORMER either from the above or similar electronics store location.
3) Other examples and ground loop explanations for both Video & Audio can be found at the following link for information about ground loop; scroll to Why Ground Loop is a Problem:
4) Other commercial antenna signal isolators are available on the web or simply see your local Radio Shack
5) Connect the isolator device chosen to your set-top box and hook it back up.
You will be back-up and running in no time.
Dec 29, 2007 | ASK Proxima Proxima DP2000S Data Video...
Proxima DP2000x
that model has issues with the power supply board. unfortunately, there are no replacement boards.
Oct 19, 2007 | ASK Proxima Proxima DP2000X Multimedia...
InFocus Proxima DP2000S Multimedia Projector Logo
243 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
