Question about Epson TM-T88III Thermal Printer
EPSON TM-T88II Serial to USB connection
I have an EPSON TM-T88II that I want to connect to a laptop without a serial port. I bought a serial to USB converter and have connected the printer to the laptop and installed the EPSON drivers perfectly, however when I go into the control panel/printer to try to print a test page the printer status is 'unavailable' and the test page appears in the queue then disappears without printing?
Need drivers for win 7 for TM-T88II
1. Do you get any error message?
I would suggest you to follow these steps and check if it helps.
Method 1:
Try following the steps mentioned in the below link to install the printer and check if it helps:
http://windows.microsoft.com/en-us/windows7/Install-a-printer
Method 2:
Try downloading the drivers from the below link, install and check if it helps:
https://www.epson-pos.com/cgi-bin/sdssm/main/soft.jsp?BV_SessionID=@@@@0883895352.1281895967@@@@&BV_EngineID=ccceadeldldgdljcefeceeedfhldfkl.0&oid=12885&sub_id=12888
or
Download and save the Windows Advanced Printer driver package from here..
http://pos.epson.com/developers/techresdetails.htm?productpk=642
When downloaded, double click the file to start the unzip process..
You will see a PDF document in the list to be unzipped..
Double click the PDF to open it and then save the PDF to your hard drive..
There is a section in the document which explains how to install the printer in Windows 7 32 and 64-bit..
Jul 12, 2012 | Epson Tm-t88ii M129b Pos Thermal Receipt...
The printer is install but will not print not sure if it is on the correct port, what port should i choose i am using windows xp pro
Please read the users manual for printer compatibility. What operating system is compatible for this printer. If not, parallel port is the quickest way to connect to printer, just install the printer software and it is ready to print. But if you are using USB port. sometimes you need usb driver to be able to connect to printer. Check for usb port driver for this printer before installing.
Nov 19, 2010 | Epson TM T88II Label Printer
Epson TM 88II not working with Win XP SP2
Are you confident this is using a parallel interface?
The ones I used to work with used a 25pin to 9pin serial connection. The 25 pin connection on the printer is the same as a parrallel port on a PC, but if you think of a normal parallel lead the printer should use a 'centronics' connector to conform to this. I think you may need a 25pin to 9pin serial lead which aren't very common but plenty of people should still make them.
Stephen
Feb 18, 2010 | Epson TM T88II Label Printer
Connecting Epson TM U220D printer with Laptop (having Windows XP)
Please verify if you properly install the port converter, its drivers.
Aug 31, 2008 | Epson TM-U220 Matrix Printer
Can't install epson tm-t88iii serial
unistall the epson driver.
reboot your system.
connect and turn on the printer.
reinstall the driver, v3.02, selecting for create a serial port.
choose the right setting os serial interface.
after install, reboot your system.
it works to me.
Aug 19, 2008 | Epson TM-T88III Thermal Printer
VeriFone Tranz 330 Printer Cable to Epson TM-T88iii Printer
Absolutely not. The Tranz 330 port is an RS232 serial port.
Mar 12, 2008 | Televison & Video
Have epson pos thermal printer with wrong interface
RS232 and Centronics interfaces are incompatible. You need to connect the printer to a SERIAL port not a PARALELL
Oct 06, 2007 | Epson TM T88II Label Printer
Epson TM-T88III Thermal Printer Logo
1,767 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
