Question about Hampton Bay (261025) Dual Mount Ceiling Fan
Need to tighten the ceiling fan but cannot get the cover off the top near the ceiling! How do you remove the cover with wrecking the whole thing?
  • 3,600 Answers
Does it have a light kit? if it does remove the likt kit and inside you will see a black and white wire be sure to turn wall switch off and tpe it to the off postion once the light kit is off you will see a shaft that runs from the center up to the cealing you will see a nut that is on the threded shaft remove that nut to get to the upper part of the motor. and reinstall after words. you can also go to hampton bay web site and you can see a parts blow up of your fan and you will see how it works. hope this helps. go to this web site and sign in and you can get the picture.
http://www.homedepot.com/webapp/wcs/stores/servlet/ContentView?pn=KH_BP_LF_Hampton_Bay_brand&langId=-1&storeId=10051&catalogId=10053&cm_sp=THD_Marketing-_-hampton_bay_brand_page-_-vanity09
Posted on Sep 29, 2009
Testimonial: "thanks it was very helpful!"
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
I was trying to see if I could stop my fan from wobbling. After loosening the 2 phillips screws I twisted the upper housing slightly and the complete fan came loose(except for the wires). I just want to...
The fan wobbles cause you bought a crappy Harbor Breeze or Hampton Bay fan. The fan blades need to be balanced with a fan balance kit that comes in the box. You probably threw it out cause you didn't know what the package of weights was for. Get you a Hunter ceiling fan and you won't have an issue with fan wobble, because their fans have better quality control before leaving the factory. If you installed the fan without adequate bracket support- you best get a pro to help you out cause there is no fan wobble help for stupidity.
Jun 05, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
52 inch ceiling fan hampton bay--Humming..... Tightened blades,adjusted fan blades, changed to a new wall switch, blade to ceiling height O.K.... still humms, what can I do??? thank you
Sounds like you have covered all the bases already, but there is the small possibility that it is the housing vibrating. You can remove it and buffer the adjoining parts with electrical tape on the inside (so as to be hidden). Otherwise, you have a fan that hums (many just do). May need to exchange for a known quiet model like a Hunter or Panasonic.
Farmerbear at FixYa.com
Oct 01, 2010 | Hampton Bay 24002 Ceiling Fan
Fix a fan that is hanging loose from ceiling. Do I
Hi .. no you should be able to just drop the canopy cover ,, and be able to see what is loose at the ceiling .. it may be the mounting plate where it connects tio the ceiling box.
Jun 26, 2010 | Hampton Bay 24002 Ceiling Fan
I can't find any mounting screws or bolts on the ceiling fan motor assembly. How do I remove it from the ceiling?
Yopu first need to drop the canopy co0ver from the ceiling mount. The cover may have screws at the very top edge. It may have screws at the bottom plate. It may have a decorative plastic ring at the very top that is conceling the mounting screws. You should be able to twist the plastic ring in an unscrewing motion and pull down to remove it.
Mar 10, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Cannot remove casing around ceiling. Hampton Bay
Try twisting the bezel (cover) counterclockwise to unlock it from the mounting base plate on the ceiling. The other option is to see if the bezel/cowl has fasters (screws) holding it in place either from the sides near the top edge or at the bottom nearest the narrow portion of the cover.
Sometimes the fan cowl bezel is fastened using screws at the point nearest the motor shaft.
There could also be a trim ring that needs to be gently pryed off from the edge nearest the ceiling, so you can gain access to the screws that are holding the cowl in place on the mounting plate. There are usually 2 sets of 2 screws placed 180 degees apart from each other that secure the cowl in place.
I hope you find this Very Helpful and best regards!
Aug 20, 2009 | Hampton Bay Dryers
Dont know how to remove blades
look as far up as you ca... it may be one of those fans that the whole thing is attached to each other... my dad had to take the whole thing down one time in order to unscrew them
Apr 02, 2009 | Hunter 23852 Classic Original Ceiling Fan
Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
Jun 22, 2008 | Refrigerators
Removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
Light bulb
I was just looking at these fans. One site said to use the palm of your hand to turn the light cover 1/2 trun. I can't remember which way to turn.
May 16, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Hampton Bay (261025) Dual Mount Ceiling Fan Logo
423 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
