Question about Shimano Cycling
Shimano lx m569 shifter assembly diagrams
Shimano lx 8spd m569 shifter assembly .Has anybody got any diagrams/assembly instructions for above shifters. LH shifter (fr Chainrings) won't shift from middle to outer ring.Hoping to do a reassemble/adjustment if possible. Any clues?
  • wkarric1 Sep 16, 2010
    i have a shimano shifter diagram so i can put it back togather.
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
What kind of components do I need?
Most bikes have Shimano shifters & deraillers; SRAM is the other main vendor. Shimano makes a wide range; the following table attempts to describe these and presents my best guess of where the SRAM line fits in: Model Quality SRAM Equivalent?
SIS, Tourney (or just says Shimano) Mainly designed for riding around the neighborhood
Altus Sufficient for paved or very easy trails; avoid hills 3.0
Acera Slightly better, but won't shift well under stress; capable for easy casual riding 4.0
Alivio Minimal capable for recreational riding; will handle some hard riding 5.0
STX / Deore Entry-level components for hard riding; tough & reliable 7.0
LX The minimum standard for hard riding. Reliable & responsive 9.0
XT More responsive than LX, but still reasonable tough 9.0SL
XTR Light, responsive racing components; tend to be quite expensive; often sacrifices toughness for responsiveness X.0
Look for a component set that fits your expected riding style.
Note:The numbered SRAM components aren't compatible with Shimano components. SRAM does make grip-shifters that are Shimano-compatible.
There are many other manufacturers that specialize in various components (Avid, Cane Creek, Race Face, Hope) and make great ones. Ask the LBS personnel for a comparison if you see a brand you don't know. Also, you can use the same test as forks above: if its not sold separately, its probably more questionable. If you're getting a full-suspension bike, make sure you get a good rear shock as well (it'll probably be something other than SRAM or Shimano).
Dec 16, 2010 | Cycling
With Shimano 6603 Group can you use Shimano 5703 shifters, or even triple Tiagra shifters?? Thanks for the reply
The answer is yes and no.
The 5703 shifters will work both derailleurs and match the 6603 group as they are both 10spd.
The Tiagra will not work because it is 9spd, it will functionally shift the derailluer but you will not be able to line up the gearing.
The rear shifter needs to match the number of gears on the back (cassette) in the case of the 6603 group that is 10spd, so you can use any 10spd rear shifter from shimano. The Tiagra is either an 8spd or 9spd depending on the model and will not work with the cassette. You can use a 6603 rear derailleur with a Tiagra group, as long as the shifter and cassette are both the same.
Dec 14, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
Question, . . need to replace chain Will a Sram PC-971 Chain work on my 8 speed road bike? Thanks T.K Yandell
Nope - This is a 9spd chain. The gears on a 9spd are narrower than on an 8spd. If you are going to use a SRAM chain you need one that starts with an 8 such as PC-850.
Any 8spd chain will work fine, Shimano, SRAM, whatever.
Nov 21, 2010 | Cycling
Shimano tiagra 9 speed shifters how to change gear
Go to http://techdocs.shimano.com/techdocs/index.jsp
Search in drop down list to go to all tiagra items and identify your particular components. Shimano are good at numbering their parts and you should find the number you seek on the bicycle component. You will usually be able to download an exploded parts diagram and service instructions. The service instructions are prefixed by the letters SI.
Nov 21, 2009 | Cycling
Shimano Deore LX right hand rear shifter
HERE is Shimano's exploded-view diagram of the shifters, but it really only gives you a ballpark idea of the assembly. You will have to piece the rest together from memory, i suppose. Sorry, i could not find more information for you.
Hope this helps a little,
matt
Oct 07, 2009 | Mountain Shimano Deore Bicycle...
8speed lx shifter to xt shifter
It depends.. Shifter cables are standard and the same one would work for both LX and XT shifters. If the old cable is full of grime etc, it is a good idea to run new cables - it will give you a smooth easy shift.
I am sure if you check www.shimano.com you will find the manual for your model of shifter. Replacing cables is pretty easy.
Jan 24, 2009 | Mountain Shimano Deore Bicycle...
Cycling Logo
2,691 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
