Question about Dishwashers
WHAT CONNECTIOS HAVE TO BE REMOVED TO TAKE OUT
WHAT CONNECTIONS HAVE TO BE REMOVED TO TAKE OUT KENMORE DISHWASHER
    President:
  • 1,185 Answers
Mains supply , drain tube and water inlet or inlets as per specification
One should be a wall plug , one should be a tube into a standpipe or drain and the other one or two should be removed by unscrewing the plastic nuts holding them to the rear of the machine
Make sure you turn the water off at the wall then switch the machine on as if to do a load , this will de-pressurise the hose/s
Posted on Sep 29, 2009
Testimonial: "THANK YOU - shall use this infor this weekend"
Replacement motor arrived. Slightly different. The old motor had a proprietary kenmore electrical connection.
Sears Appliance - Dishwashers - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Dishwashers
Rating: 1 - ‎80 votes
We have ordered new wheels but the price for plastic wheels seemed a little high ....Hose came loose, water pours out and into my basement, pump slips out of slot ..... I will NOT be buying another Kenmore dishwasher when I do replace it.
Sears Appliance - Dishwashers ' Page 2 - ConsumerAffairs ...
We bought a Kenmore dishwasher from Sears a little over 1 year ago and ....Switchboard being replaced 3 times, motors and wiring being replaced they still will ....Another tech came out and said "Well they didn't program the motherboard" so ...
Kenmore Dishwasher Parts - PartSelect
www.partselect.com/Kenmore-Dishwasher-Parts.htm
Dec 22, 2015 | Kenmore Dishwashers
Kenmore dishwasher 665-15805890 parts
If the dishwasher is connected to a disposal, there is a knock-out on
the disposal inside the stub on, a screwdriver will remove it. Catch it
so it will not go in the disposal.
May 12, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Water not getting to dishwasher
Hi jorrico943
Check in the back of the dishwasher where the water feed comes into the machine. You will see a soilnoid that has the water connection to it...shut your water off and remove,clean, or replace the solinoid it sounds to be defective or dirty.
Sep 20, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dishwasher wont work
Remove the console panel with T15. then remove the cover from the main control board. top right of center of the main control you will see a removable fuse, either a black disc with a black and a black/w white strip connected. remove one wire from the thermal fuse and check for continuity. if it is open replace it. if it is not open call for service.
Apr 30, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher elite door opens too fast, broken spring?
Could be that, the spring may have unhooked or it could be a defective damper connected to the door. Remove the side panels and check the operation of the door mechanism. (This will probably require the removal of the rear panel to gain access to the necessary fastners).
Jan 21, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore Elite Not cleaning dishes
You might want to check where the hose from the air gap connects to the disposal there is a plug that has to be removed to allow for the washer to drain.
Mar 15, 2009 | Kenmore 24 in. 17303 Built-in Dishwasher
Control panel access
Open the door and remove the top screws connected to the console. Close the door and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Mar 06, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
How do I acess the control panel
Open the door and remove the top screws connected to the console. Close the door (not locked) and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Kenmore 17245 won't drain.
Try blowing into the drain line with a wet/dry vac. This sometimes removes clogs. Otherwise, hold the hose above the unit and fill it with water. If there is no clog the water should appear at the bottom of the dishwasher after a few quarts.
Nov 29, 2007 | Kenmore 17245 Dishwasher
Stopped working altogether
Check the door switch, it may have gone bad or maybe isnt connecting with the catch, making it look dead. They wont do anything when the door is open, as you know. Also remove the lower panels to get to the inside of the dishwasher. Check for power where the cord is plugged into the machine. If you have power, unplug it and look at the terminals to the heaater element. They are on the right side, facing down out of the dishwasher tub. Just look inside the dishwasher to see where the heater goes through, then look in the same place underneath, Check the condition of these connections. The timer gets power through the heater element (strange but true) so if the heater is bad or these connections have heated and melted, it will cause a dead dishwasher. if tis just the connectio, pu t a new terminal on it and you should be good to go. Hope this helps
Jun 19, 2007 | Asko D1716 Built-in Dishwasher
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
