Question about Dell U0636 Mouse
My dell bluetooth mouse stopped working. I replaced batteries, but does not work. I have studio laptop with built in bluetooth card
What OS are you running, is it vista? if so, I had same problem. the dell Tech had me uninstall service pack 2 and then the mouse would activate properly
Posted on Dec 16, 2009
E6410 Bluetooth randomly shuts off
The mouse is the issue, check all connections and battery contacts, if unit can run on standard battery, " replace " to see if that will help, and make sure wfi plugged into laptop properly,also try another usb plug on your laptop.
Apr 02, 2012 | Dell Latitude E6410 Notebook PC Core i7...
Dell XPS M1530 bluetooth wireless mouse
since it is a wireless bluetooth mouse, you should make sure that each time you restart your system make sure that the bluetoth is enabled nd working. Also see the battery check on the mouse. if you are having more than one USB port, make sure you try on them too. Hope to hear from you.
Thankyou
Mar 20, 2008 | Dell U0636 Mouse
I have brought my wireless keyboard and mouse to India with my laptop - they worked fine in the UK but on arrival here I can't make them 'talk' to each other at all! Have replaced the batteries and the...
Hi, two points of failure that I can see on your issue. First could be the BT software, 2nd could be the BT card which is a hardware issue. My first suggestion is to go to Control Panel, then Add/Remove Programs, look for and application named SetPoint then remove it. Most likely you're probably using a DELL computer, if so go to http://www.support.dell.com/ go to Drivers and Downloads choose your correct Computer model maybe laptop or pc; then choose your correct Operating system and platform if its 32 bit or 64 bit. Next update your Chipset driver, System Utilities - Notebook System for laptops and Dell System software for pc, then update your Input device driver - Bluetooth Wireless Keyboard and mouse Bundle, then update your Quickset under Applications and Synaptics driver under Input device drivers if it's a laptop you have, after doing everything restart your pc. If all is done correctly and still won't work work contact the manufacturer to replace your Bluetooth card since it's already a hardware failure. Thanks and have a nice day! =)
Jul 30, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Blue tooth icon missing from system tray now Dell blue tooth mouse wont work
You need to connect a wired usb mouse first and try pairing the bluetooth mouse again with your system by going to the control panel and opening your bluetooth device manager. Click add a device and press the connect button underneath your mouse. System should be able to detect your mouse. If that failed, try replacing the batteries with fresh ones.
May 24, 2010 | Dell Studio 17 Laptop
Power and mouse probelm
there is something wrong with your battery even though the laptop shows that the battery is fully charged.
You need to get another battery for your laptop as the one you are using presently cannot hold charge, that is, the cell in the battery is weak.
Good luck.
May 01, 2010 | Dell Studio 1537 Notebook
Driver for Dell BT Travel Mouse
If it is a dell mouse, it should automatically work after a few things. Simply locate the button on your mouse to power it on, open your bluetooth settings on your computer and scan. It will then add the drivers as a HID (human interface device). If that fails go to dell.com, search for drivers & downloads under support and search for the drivers & documentation.
Mar 31, 2010 | Dell Studio 17 Laptop
Dell Studio Bluetooth Not Working
if ur OS is windows 7 it does not need any bluetooth soft..
Mar 02, 2010 | Dell Studio 17 Laptop
Dell Studio 15 laptop mouse does not work at start up.
It sounds to me like the mouse buillt into your laptop is conflicting with the Dell external mouse. If you go into control panel and click on mouse, you can disable your built-in mouse. Restart your computer with the USB mouse plugged in and see if that does the trick. I would be surprised if it does not. On the off chance it doesn't work, you will have to enable your built-in mouse and we can check to see if there are any additional conflicts happening through your hardware profiles in the system area of control panel.
Jun 21, 2009 | Dell U0636 Mouse
CANNOT CONNECT WIRELESS MOUSE TO DELL INSPIRON 1525
make sure your usb ports are turned on in the bios
Apr 11, 2009 | Dell Inspiron 1525 Notebook
How to connect blue tooth mouse to dell inspirom 1520
Hold on... are you sure that you have a bluetooth mouse or do you have a wireless mouse with "pen drive" like dongle? If it is with a dongle, it probably is a common wireless mouse which operates on its own wireless frequecy. You may have a driver CD that comes with the mouse or it simply works "plug and play". However, there are bluetooth mouse too, in this case you just need to turn on your bluetooth on the PC and pair the mouse with your PC just like any other bluetooth device. In either case, a LAN card in not involved. Hope this helps.
Apr 04, 2009 | Dell Inspiron 1525 Notebook
Dell U0636 Mouse Logo
758 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
