Question about Kitchen Appliances - Others
Prolectrix wall fire where do I buy the brackets
Prolectrix flueless wall mounted electric log effect wall fire
I cannot find out where to buy any brackets or how to mount it.
Highdefjeff
  • 124 Answers
SOURCE: 42'' LCD PLTV-4250 MOUNTING
The universal mounts generally have a selection of screws that are to fit different makes and models of tvs.
If you bought the appropriate size mount for the size of your TV, there should be mounting holes that match your TV, and screws that will secure it.
I have not seen any mounts that use more than four.
Posted on Apr 08, 2008
SOURCE: Mounting the bracket to the tv?
Hey, I had the same problem and finally found this solution (the four mounting holes are covered by plastic caps as I thought ... just wanted to be sure). Hop this helps:
http://www.avsforum.com/avs-vb/showthread.php?t=1040337
Posted on Dec 27, 2008
  • 11 Answers
SOURCE: how do i mount the brackets on the back of the tv
There is a good guide for tv wall mounting/brackets, see it here:
http://www.mountright.com/articles/
Posted on Sep 14, 2009
  • 12128 Answers
SOURCE: Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Posted on Apr 18, 2010
jyackle5
  • 8197 Answers
SOURCE: When buying a wall mounted range hood, do I need
If you are going to use the hood ductless you just need to make sure that it comes with a charcoal filter or buy one at the time. Also you need to make sure the hood can be used ductless.
Posted on May 08, 2010
How to make ice cream?
You want to make ice cream with a fireplace? Interesting.
Jul 30, 2014 | Unknown ProLectrix 80-4998 Windsor Wall or...
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
What's involved in wall-mounting a flat-panel TV?
Actually, wall-mounting your TV is a pretty simple task. You'll need to buy the right bracket to fit the size of your TV and also meet the right distance range you want. The procedure is explaining in every bracket you buy and involves drilling a couple of little holes in the wall.
Jul 29, 2012 | Furniture
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
Can I wall mount my proview tv? do I need to buy a particular mounting bracket?
You can wall mount your Proview TV with any standard VESA mounting system that is certified for up to the size of you tv.
Feb 03, 2011 | Sony SUWL500 Wall Mounting Bracket
I have a wall mounted electric fire with flame option,I have changed the bulb but cannot get the flame effect to work. The falme wheel is turning but no light effect.
have you checked fuse to bulb some electric heaters have a fuse for bulbs and fans so it might be a small inline fuse that you need to change
Nov 22, 2010 | Heating & Cooling
I bought a PROlectrix Balmoral electric fireplace but there are no instructions with it...
Hello! Do a search.. there is one company.. something like smgeneral that has instructions you can download free.
Looks like the instructions are easy enough, but it will take two people unless you can support the fireplace somehow. Most of it is safety. I bought one of these, but have not opened the box.. just saw your problem and remember seeing directions. Search was: prolectrix balmoral electric wall fireplace and found instructions. Good Luck!
Sep 30, 2010 | Fire Sense 02691 Black Wall Mounted...
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
Im have a flueless gas fire which was installed before Christmas however I am reluctant to use it as the wall it is attached to becomes unbearably hot and has cracked my plaster wall. Also there seems to...
Something doesn't seem right to me, I've installed enough of them to know you shouldn't be burning the wall...the smell could be the ceramic logs, if it has them, or the ceramic blocks, but only the first few times, after that, I'd be suspecting the wall, not good. Call the installer...
Feb 27, 2010 | Heating & Cooling
Kitchen Appliances - Others Logo
89 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
