When i print the text comes out all tiny like a bar code
  • Richard Klein
    Richard Klein May 11, 2010
    What is the make of the printer. It sound like its printing the error code the the service tech would use to fix it.
I loaded the windows update driver and connected my PSC 2115 all in one printer. It prints text documents and the test page without any issues. It displays images in print prieview but won't print them.
You need to get the manual for this printer, it has a printing language all it's own. The encoded text tells it where to put the bar code on the label, how to encode it, what text to put under it, etc. It's looking for a specially designed print file that's plain text. There may be a way to turn that off and turn it into a bitmap printer, but you would need the manual for that.
Nov 23, 2010 | Zebra 105SL Thermal Label Printer
I have two printer and on one the label size comes out with the correct font size but when I try to print out the same label on the second one the bar code and human readable is much larger...am I missing...
Yes. You have two printers that have different "dots per inch" print heads. The printer with the correct size font is a 300dpi printer and the second one is a 203dpi printer. That's why the bar code and text is printing larger with the same code being sent to the first printer. The dots on the printhead are larger therefore, larger print.
Change the printer driver on the second printer to Z105SL-300 dpi and the print will be just fine.
Hope that helps !
Jun 15, 2010 | Zebra 105Se Thermal Printer
We presently have a Zebra 110XiIII Plus Printer that we use for printing labels containing Text and Bar Codes from an MS Access based application. Our current printer comes with a Roll of paper, and labels...
@ gould804.
I have the same model printer and utilizing it the same way with text and bar code. My issue is not the the font but rather the text is not printing, only the bar code. Maybe we can contact and work with each other to resolve both of your issues. let me know?
Nov 19, 2009 | Zebra 110Xi III Plus Thermal Printer
3 Model 2746's - 2 print custom label perfectly - the other does not.
could be the printer speed but, you may want to reinstall driver and reset configuration, sometimes it is just one thing unchecked that will make the diference.
May 20, 2009 | Zebra 105SL Thermal Label Printer
HP2100 laserjet won't print inserted pix in Word 2007 doc
I ended up fixing this problem myself.
I needed to set the printing resolution in the HP printing dialog box to 1200 x 1200 dpi as the HP2100 can print at this resolution.
Select: Print/Properties/Advanced/Graphics. Then set the printquality to 1200 x 1200 dpi.
Rod Salter
Dec 15, 2008 | HP LaserJet 2100 Printer
Need to enlarge the print on my HP DeskjetD4160 - it's soo tiny
Are you using Internet Explorer, as you brower? If so go tothe top of an open browser window left click on "page", go down to text size and select the size you want. If you don's see "page" click on menu bar, it should open up the options available, there. It's right next to tools. that should do it. Also if you want larger text when viewing websites, click on View, and you can adjust the text the way you want it to look.
Dec 03, 2008 | Computers & Internet
Enlarging print size
if you use Mozilla Firefox for your web browser (click here to go to the Mozilla site) when you print you can zoom in and out if you go to file > page setup the screen below will come up just un click shrink to fit page and enter in a zoom scale (larger makes your text lager & smaller makes your text smaller)
also with Mozilla you can zoom in and out on the page you are viewing by holding down 'ctrl' on your keyboard and clicking the + key to zoom in and the - key to zoom out.
i hope this has been helpful.
May 09, 2008 | Office Equipment & Supplies
Bar codes appear solid back
I have problem with the same printer, the bar code is not printed, someone can help me?
Apr 09, 2008 | Zebra 105Se Thermal Printer
Print size
Try going to Start>Control Panel>Make sure your in classic view>Printers And Faxes>Right click on your printer>choose properties>click "Print Test Page"
Is the text small on the page that comes out?
Jan 17, 2008 | Epson Stylus C84 InkJet Printer
Text comes out looking like bar codes from HP 3055 all in one
i would suggest changing the toner cartridge, if that doesn't work, i would install a new laser scanner motor.
Apr 10, 2007 | HP LaserJet 3055 All-In-One Printer
21 people viewed this question
k24674
