Question about Matrix Star SP200 Receipt Printer
We lost our electricity for about 10 seconds
We have a Star sp200-2 sp212FC parallel port receipt printer.
We lost our electricity for about 10 seconds during a windy rain storm (not an electrical storm). The receipt printer did not come back on after that power failure. I unplugged and re-plugged it in and I turned the toggle switch on and off but it still doesn't work. We've had the pritner for almost 6 years.
3 Suggested Answers
computafixa
  • 317 Answers
SOURCE: Star SP200 (212FC) Parallel on LPT3 wont print but once unless you cycle power?
try reinstalling the printer in the printer and faxes window under the controll panel by clicking on it and hitting the delete key, now select add a printer from the sidebar, and follow the instructions in the Wizard. Also check the printer settings and see if they are set to the defaults
Posted on Jan 09, 2008
SOURCE: opening drawer through star sp200
code for star printer sp200 open drawer code ( tested and works ) 27,7,11,55,7
Posted on Oct 25, 2008
Star tps 100 not producing reciept intermittantly
Is this the networked Star TSP or the USB version? If it's networked you may want to make sure that you're still connected to the network by printing out a test receipt (power the printer off, hold the feed button down while it's off and continue holding the feed button after turning the printer back on until it prints a test receipt - the second receipt will give IP configuration information).
If you're not receiving a valid IP address you may be having network issues - you might consider assigning the printer (you might need to power cycle your router and printer to get initially connected again in order to do this).
You can also try resetting the printer to its default configuration - you can find instructions here:
Star TSP100Lan Network Troubleshooting Unable to Detect the Printer within...
Oct 25, 2014 | Star Micronics TSP100 Thermal Printer
Jan 09, 2008 | Matrix Star SP200 Receipt Printer
Printer stays offline
open printer and fax
right click on printer
select properties
select port atb
chaining port to usb vartuala port
try with port 2 and all
Mar 14, 2014 | Star 37999190 -Micronics Sp712mc Dot...
Trying to set up star tsp100 printer as a receipt printer on averasell pos software. Have installed the printer and it prints test page fine. However when I try and do an invoice on averasell the cashdraw...
... For windows 7 YOU MUST go to your printers properties and click the advanced tab and change it from PRINT SPOOL to PRINT DIRECTLY TO PRINTER...
and if you want your receipt to print off to the right size... install a second copy of the STAR TSP100 and set it as (COM3)... (make sure in the properties you change the paper size to 72 X receipt and cut to partial) i'd do it on both copies
as well go in to the virtual port config and add COM 3 and COM 4
then go to the averasel station properties and set cash drawer as com 4 with the generic/text printer and then under invoices set the print drivers as the star tsp100 copy (the one that is on com3)
and set the actual printer as Star Tsp100(the one that is usb)
sorry for the some what confusing step's perhaps someone else can word it better as i do not have the software in front of me right now...
but my end result was a cash drawer that opened
a printer that printed TO THE RIGHT SIZE and not a full page
Mar 28, 2011 | Star Micronics TSP 1000 Thermal Printer
I have a TSP700 parallel port label printer and now have a new computer with no parallel port, so I purchased an adapter;- parallel to USB, but having tried every thing, I am running, windows XP pro, I...
you might need to fiddle around with the usb virtual printer port configuration , when you add printer. when adding a printer, uncheck the install automatically tick box, then on the NEXT page click on the drop down list of "use the following port" and try virtual port. it might work.
Mar 21, 2010 | Star Manufacturing Star TSP700 Receipt...
My star sp200 will not print when asked. The "online" light is not lit up (I'm not sure if it was on before the problem) When I unplug the printer port cord, the online light comes on and the feed button...
1. check the usb or parallel cord to the PC to see if it is connected proper ly
2. clear all print document on the pc
3. If the "online" light will not come on this may mean that the cord is not completely in the connection socket.
4. check Dip switch for parallel cable ( should be 3 ON, 4 ON, 5 ON) this is for USA settings
5. check paper roll ( if at the end of roll it will shut down if proper paper load is loaded.
6. When temperature at the print head is high printer will go "offline"
7. check the alignment of the ribbon also
Mar 18, 2010 | Matrix Star SP200 Receipt Printer
Is it possible to connect an old, still very efficient HP 5L Laserjet Printer which uses parellel port cable to a new computer via a USB cable? If yes, what do I need?
Yes it is. You just need a Parallel to USB adapter. Here is a link to an example of what you need.
Parallel to USB
I have done this several times with Parallel Receipt Printers. Works Great!!
Another option would be to add a Parallel Port to your new computer. Here is another link.
PCI Parallel Card
The 1st option is probably the cheapest and easiest.
Good luck and have a great day!
Feb 26, 2010 | Office Equipment & Supplies
Mb password lost
Only solution is to buy, or make on your own, a parallel port password removal key. You can probably get a cheap one on eBay for around $10, or make one using an old, parallel printer cable. The wiring schematics is available for free (just google it). Plug the key into the parallel printer port, turn on the laptop, and the CMOS password will be removed.
Feb 13, 2010 | Toshiba Satellite Pro 490CDT Notebook
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Matrix Star SP200 Receipt Printer Logo
22 people viewed this question
Top Matrix Office Equipment & Supplies Experts
Dimitar Todorov
ray gallant
Tom Chichester
Are you a Matrix Office Equipment and Supply Expert? Answer questions, earn points and help others
