Question about Whirlpool Duet GHW9150P Front Load Washer
There is water running into the drum of my washing machine when the unit is off. over a 12 hr period the tank fills half way up the door. I would assume there is trash in the water valve keeping it open enough for waster to pass.
    Genius:
  • Whirlpool Master
  • 1,474 Answers
Cold be the valve turn it off to check..Could also be drain on sink too low water feeding back ..good luck
Posted on Sep 29, 2009
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
I purchased a LG 24cu ft French door fridge, manual says it takes 12-24 hr to make ice. When I hooked up the water should it have filled the icemaker or will it do that after the 12/24 hr period?
it will take about 12-24 hrs for the unit to be at the controlled temperature that you want -during that time it will be be trying to make ice if you have water hook up turn on the ice maker -but it will take awhile since the unit wont be at temp for the ice to form and accumulate
Jun 29, 2016 | LG Refrigerators
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
Malber P28 washer. On hot water cycle the drum is part filling with water then stopping wash cycle and door is unlocking. I was able to open the front loading door with the drum half full of water - gushed...
Sounds like a control pcb malfunction. Remember that you are dealing with MAINS Voltages which can be lethal.
Never continue to use a machine that floods or enables random water release for any reason. The end result might be Electrocution, and it is certainly not worth that risk
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 04, 2013 | Malber P28 Front Load All-in-One Washer /...
Leaks water from bottom of door. Error code E7 ?
I found this and it also may have to do with the door seals...how old is the unit...if door seals get old and stiff..(not soft and pliable) they sometimes leak...after usage the heat and moisture may cause them to swell and or become soft thereby sealing better...but this is what I found in the user manual.
Machine displays "E7" on LX30 model or "CLEAN PROBE" on LX40 model.
1. Clean water sensors inside tank.
It suggests contacting Hobart if this fails but I also found this problem is associated with fill issues...as in an E4 error...this what you do in that case....
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Good Luck and I hope this helps...let me know if it doesn't and i am sure I can get to the bottom of it...thanks for rating my effort...the Fang.
May 19, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Whirlpool Duet Washer Leaking
For those wondering about replacing the water inlet valve - this is a very simple undertaking.  You can find the part online for around 40 bucks.  All you have to do is unplug the washer, detach the hot and cold supply hoses, remove the lid (3 torx bits on my model) unhook the water line from the old inlet valve (conveniently accessible at the top right of the unit from the rear), unhook the electrical connections (be sure to label these for later re-attachment), unscrew the 1 screw holding the valve in place, and reverse the process with the new valve.  I'm hoping this will stop water accumulating in the drum - I'll update later if it does not.
Jan 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
113 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
