JVC DR-M150 DVD recorder - loads disc, plays intro/goes to root directory then says "Please Wait". after a minute or so shuts down.
Fan runs OK.
SOURCE: JVC DR-M100S
try recording on a re-writeable dvd i had exactly the same problem on a dr-m100 (the more primitive version of the dr-m100s) as follows: -- heard a distinct pop while recording -- after that, an error message indicating that i am trying to record on a write protected disk, even though i am not. recording on standard blank dvd now impossible. -- unit still plays dvd normally, except it takes twice as long to find beginning of program -- wierdly, it still records on re-writeable dvd's. the re-writeable dvd must be formatted correctly. the unit still formats re-writeable dvds normally
SOURCE: LG DR-4810 DVD Displays " PLEASE WAIT"
C113 10v 1000uF cap off an XFRMR in power supply board. Cooked and gone high esr. Replace with a 16v.
SOURCE: JVC DR-MX1S
This machine has a lot of problems. One thing that often works is to turn it off and unplug it for a couple of minutes. Then plug it in again. Then it will say "loading" for quite a while. Leave it alone until it turns itself on. Then it should be okay. If the couple of minutes doesn't work, sometimes unplugged overnight (same method) works, but then you have to reset everything.
SOURCE: JVC DR-M10 DVD Recorder not working
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
