Question about Desa International RFN30T Open Flame Mid-Size Heater
Desa pilot light
Will go out when it turns off fire abiout once a week. I relight pilot and it will work for 2 up to 20 times before it goes out again
  • Anonymous Jan 07, 2008
    I can not get the unit to light.
    It seems as if there is no spark for polit light.
    How do I replace the lighting unit?
  • 625 Answers
Check for a restriction in the pilot line - perhaps a spider web or maybe a mud wasp decided to make a residence in your heater.
Posted on Dec 27, 2007
The pilot light goes out, when I relight it and fire up its o.k. for a few minutes and then the pilot goes out again.
change the thermal couple if it still does it you could have a clogged orifice or bad gas valve
Mar 13, 2015 | Heating & Cooling
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
I have a Desa EFP33PR ventless fireplace. In Auto it works just fine. In Manaul the pilot will light but when I release the gas valve control knob it goes out. Some times, if I rotate the control knob...
It sound like you may need to clean the pilot on the fireplace and then reseat the thermocouple.
Here is a link you may want to look at:
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Sep 13, 2011 | Desa International Unvented Gas Space...
When you first light the pilot works fine after cooker heats up it may cycle a few times and the pilot goes out and then when you try to relight it will only stay lit while the pilot button is being...
Hi there. Try cleaning the thermopile, it must be free of soot or any other form of dirt, the pilot flame should be of good quality, as well as the gas pressure.
Regards.
Aug 02, 2011 | Imperial IFST25 Deep Fryer
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Nov 22, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Burner won't light
I left it off for a couple hours and it fired back up.
Nov 08, 2008 | Procom ML300HGA Heater
Desa International RFN30T Open Flame Mid-Size Heater Logo
131 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
