Question about HP PhotoSmart M437 Digital Camera
White horizontal lines appear on all my pictures
Every time I take a picture it has horizontal white lines, viewing through the screen it looks fine until the picture is snapped then it has the horizontal white lines or if in bright light it is almost a total white out
  • 33 Answers
SOURCE: have a digital camera (canon
Definitely sounds like you have a bad CCD. Good news for you though, this particular model has been recognized by Canon to have a faulty CCD and will repair or replace your Canon A95 free-of-charge.
From Canon website:
"U.S. residents are kindly directed to contact the Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to".
Explain to them you have a bad CCD on your Canon A95 digital camera and that you are interested in having it serviced by them under the recall.
Good luck from!
Posted on Jun 18, 2008
  • 48 Answers
clean the lense
you stupid arse
Posted on Jun 26, 2008
  • 13 Answers
SOURCE: background with horizontal lines and
i have the same problem,, and i just talked with the supportgroup of hp,, and he told me it is the ccd chip,, it is broken, and you can get it fixed,, but it is cheaper for you to just buy a new camera,, hope i helped ya,,
SOURCE: Too bright picture with white lines in them
I suggest you to write a letter to Canon and to contact your local service dealer. After some struggling, they accepted the warranty claim and repaired my camera free of charge. The problem appeared when the camera was 23 months old.
Posted on Nov 05, 2008
  • 544 Answers
SOURCE: pictures are totally black
It seems you have a bad ccd imager and requires replacement.
go to your nearest service center and ask for replacement.
Posted on Mar 29, 2009
  • 1223 Answers
SOURCE: Lines on picture
Good news is u can always ask for free CCD replacement from FUJI i got it for S5000 even it was out of warranty and was not on service advisory list u have to call and ask them or email in ur region see the link for the problem
if u are in U.S just dial this number
or just go to and go to ur region link for support i am sure they will do it FREE OF COST !!
pls rate me FIXYA for help
Posted on Apr 02, 2009
0 characters
1 Points
White screen
This is a problem with shutter not fast enough opening to take a picture indoor shows the horizontal lines. In sun light it is too slow and over expose the picture. Not worth the trouble to fix, buy another camera?
Jun 26, 2012 | Olympus Digital Cameras
When i take pictures,horizontal lines appear and brightness is more
From what you said - it sounds more like a sensor problem in the camera.
If the screen looks OK while sizing up a picture , then 'click' Image is stored on sensor which is read as one LARGE matrix of dots and stored into memory.
If the white lines start at this point - ie. viewing the picture while in camera and then after download.
Then, the problem started at the sensor.
I just did a ( and did a search for problems - and NONE apart from Wi-Fi connections to Windows7 -- all reviews were great.
I would connect Nikon to see what they recommend
Feb 11, 2011 | Nikon Coolpix P2 Digital Camera
The pictures turn out either as an all white screen or with lines running horizontally accross the image
This is due to the shutter not completely closing over the lens or not firing at all. The live view on the screen looks perfectly all right because the sensor is fine. The video function should work fine as this does not use the shutter, indicating the fault lies with the shutter mechanism or more commonly the shutter leafs are stuck because of moisture residue building up.
Jan 11, 2010 | Fuji FinePix F470 Digital Camera
When taking pictures outside the view screen after picture taken appears as a bright burst of white light. Inside picture appear fine. Any ideas?
let me see if i understand. if you llok at the screen it looks ok, but after you take the picture it will record only a white bright image.....
in some cases you can easily fix this by goining into your camera option and restoring default settings. it is the exposure setting .
if you camera still giving you just black white images the light sensor in the machine ahs gone bad, it needs to be replace.
Oct 04, 2009 | Nikon COOLPIX L4 Digital Camera
Red vertical lines and horizontal flashing lines on viewing screen plus fuzzy picture.
Its bad ccd imager problem in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony DSC-W30 white's out/streaks pictures
Just call Sony if u dont have warranty in that case they will also do it free of charge i am pretty sure this is the problem thousands are facing in different brands for ur reference i am giving u a link as sony has issued service advisories like this for this type of problems dont worry if u are not on list insist they will still do it free of charge !!
kindly rate me Fixya fo rhelp !!
Apr 07, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
White lines appearing across screen
Call toll free number for support.
Ujjwal B Soni
Sep 29, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
LCD and Pictures have horizontal lines all over them.
Hmmm... your batteries ok? i had this recently and changed my NMHI batterys and cured it...
Jul 21, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Picture comes up with horizontal lines
The viewfinder is failing, or it may be a bad flexiboard, or ribbon assy. The proof is that the pictures look okay, but the viewing is not proper.
If you want it serviced, you will have to send the camera to the Sony authorized service rep. They will be able to change the necessary parts and re-adjust as required.
Jerry G.
Jul 01, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Horizontal White Lines in Pictures
I don't think [and the museum will certainly say] This has anything to do with the X-ray/storage whilst in the museums hands. It could be a processing error or a memory card error. Try formatting the card in the camera and taking a new batch of images Try another card. This will estasblish card or camera. If card - buy another card If camera -checxk on the price of a repair but I suspect it will mean when you see the price Buy another camera
Aug 28, 2007 | Fuji FinePix F470 Digital Camera
HP PhotoSmart M437 Digital Camera Logo
77 people viewed this question
Top HP Digital Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Digital Camera Expert? Answer questions, earn points and help others
