Question about Shakespeare Sport & Outdoor - Others
SHAKESPEARE SUMMIT 2909.355 REEL
I have a shakespeare summit 2909.355 boat reel. i am looking for the plastic gear on the left hand side plate,this also has a small cog on it to operate the level wind system. regards Barry Smith.
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Posted on Apr 29, 2009
  • 7 Answers
SOURCE: I have a shakespeare sigma fishing reel that
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
Posted on May 21, 2009
  • 10 Answers
SOURCE: Shakespeare fishing reel schematics
try online at www.reelschematics.com they should be able to give you help.regards barry.
Posted on Sep 29, 2009
SOURCE: My Shakespeare SKP 2000C won't reel in.
you may need to tighten or fix your drag.
Posted on Nov 26, 2009
SOURCE: shakespeare 2660 coarse fishing reel,cant remove spool cover
absolutely spot on
Posted on Apr 18, 2010
Shakespeare reel diagrams
You might want to check the numbers you provided. I found this site to have a lot of diagrams for the manufacture you provided. Mikes Reel Repair Schematics
Aug 19, 2014 | Shakespeare Agility Spinning Reel 6825
Fishing pole is supposed to be for left and right hand use, but can only be used for left hand. How to switch to right hand
Hold the bell or (metal thing on the top) so that it doesn't turn and reel in. It should start unscrewing. Theres a cap on the other side, unscrew it and put it on the left hand side. Then screw the handle in on the right side by just reeling in until the bell starts spinning.
Jun 21, 2010 | Shakespeare Surf Fishing Rod and Reel...
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
Change a right-handed reel to a left-handed reel(supreme s3035f)
you just have to unscrew the little screw that is on the opposite side as the reel and sometimes the reed will actually unscrew. You just unscrew it and screw it back onto the other side
Jan 25, 2010 | Shakespeare Agility Spinning Reel 6825
Need to know were the long spring on my sons spider man rod and reel goes
The long spring (only one in the reel) goes under the bail arm plate. To get it back in, remove the plastic cover plate on the side that pickes up the line (has a line roller on that side). The spring will fit over a small metal or plastic post and rest in a cavity at the bottom.
Screw the cover back on and you're good to go!
Best of luck
Mike
Sep 26, 2009 | Shakespeare Surf Fishing Rod and Reel...
There is a part in my Shakespeare 2916 301 Reel, so I need a Schematic drawing to ID the part, Please can you help. You can catch me on tommyrea1@hotmail.com
Your best bet is going to the Shakespeare website and they will have all the info you would need for that reel. Hope that helps!
Aug 30, 2009 | Boating
Sport & Outdoor - Others Logo
195 people viewed this question
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
