Question about Autodesk 3ds Max 9 Essentials
3ds Max 2009 Error Plugin/ Error Code 998/ Error Code 126
I'm working on 3ds max 2009 when I noticed my vray plug-in is not configured properly (no vray sun, no vray blend etc.) so I try to solve it I uninstall vray and reinstall it, but unluckily it wasn't successful for how many doing that I get tired. Right then afterwards, I tried to open my 3ds max but before max's icon showed a dialog box pop up saying ''DLL {C} Program Files/ Autodesk 3ds max 2009 plugin/ vray render 2009.dlr} failed to initialize. Error code 126. The specified module couldn't be found.'' after that another dialogue pop up, the same thing but this time the problem is in other plugin Error Code 998. Even thou I can access max I couldn't render, it's automatically close the program. I unstall and install the 3dsmax as well but the same result I got...Could someone help me to fix this problem. Tnx!
SOURCE: Autodesk 3Ds Max
its nothing but hardwork
Posted on Mar 19, 2009
SOURCE: Autodesk 3D Studio Max, not Map 3D
I found the problem. I just had to change the view from Direct. It works fine now.
Posted on Mar 10, 2008
  • 85 Answers
SOURCE: 3ds max autodesk is not opening in windows7 ultimate
some software my not be directly open in windows 7 yet, (like if u c, when u install AutoCad 2006 on Vista Ultimate u can't open it directly, 1st u have to right click on it then Run as Administrator, then it will be open and work) like this prob, i sure that u have to right click on the icon of ur software then run it as Administrator, i think it will open. and your problem will solve..
otherwise your version of 3DS Max is not compatible with Windows 7 and you have to install different version of Windows (Like Xp).
good luck.
shafky
Posted on Jun 17, 2009
  • 14 Answers
SOURCE: Please give me some url from where i can learn
Here are No. of weblinks that will help You to learn autodesk 3dsmax in an efective manner.
  • http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=6837309&linkID=9241175
  • http://www.cgarena.com/freestuff/tutorials/max/learn3dsmax/
  • http://www.tutorialized.com/tutorials/3DS-MAX/1
  • http://www.lynda.com/home/DisplayCourse.aspx?lpk2=77
  • http://www.youtube.com/watch?v=upI304tSHI0
Posted on Sep 02, 2009
Right click the 3dmax then open it with administrator.
Posted on Jan 29, 2010
Why am i not sappose to get an activation code for 3ds max 2009 "?"
Why not put this question to the firm you bought this in the first place?
We are only volunteers trying to help people with most technical questions. We don't sell things or services, we don't support anything. We don't give away free codes.
Sorry.
Jul 22, 2014 | Autodesk 3ds Max 9 Essentials
How to fix Registration-Activation Error 0015.111 Autocad2010
The reason for this error is the product key u used. I mean autodesk 3ds max has FOUR different product keys 128x1 for 3ds max, 495x1 for 3ds max design, 774x1 for entertainment creation suite premium, 661x1 for entertainment suite standard.[x=A/B/C/D/E/F depending on the year].
so reinstall the autodesk product, use a different product key( Try all these four one at a time), one will definitely work.
same thing happened to me for maya 2014, but solved it using a different product key
Jan 02, 2013 | Autodesk 3ds Max 2010 for PC
Application error 0xc0000005 in 3ds max
You're going to want to uninstall, reboot, and then re-install 3DS Max
Mar 01, 2011 | Autodesk 3ds Max 9 Essentials
3ds max 2008 64 on WIN 7 64 error (0xc0150002)
That will be a registry error.
Down load the link below and upon the finish of the scan delete all findings
http://download.cnet.com/Free-Window-Registry-Repair/3000-2086_4-10606555.html
Jul 15, 2010 | Autodesk 3ds Max for PC
Autodesk is not opening
Try reinstalling 3ds max if problem is same
1. your 3ds max is corrupt.
2. your Pc system can not handle 3ds max
Sep 03, 2009 | Autodesk 3ds Max for PC
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
Nov 03, 2008 | Computers & Internet
Autodesk 3ds Max 9 Essentials  Logo
4,029 people viewed this question
Top Autodesk Computers & Internet Experts
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
