Question about LG 42LC2D 42 in. LCD HDTV
Remote sensor on TV (LG 42PM1MA) seems to be broken. All of a sudden the remote stopped working. So I replaced the batteries. Still not working. So I figured the remote must have given up. So I went out to buy a universal remote to kill 2 flies at the same time (fewer remotes and replacement for tv remote). Now I have concluded that the old LG remote is actually OK, because the new universal remote (Logitech harmony 555) could actually learn signals from the old one... But the universal remote still cannot turn the TV off or anything else... So, what to do? Get service on the TV to fix remote sensor? Is there any other way to confirm that the sensor is broken?
  • 2 more comments
  • max_wenzin Sep 29, 2009
    I've now called service. A tech should call me back and hopefully give me a cost estimate. (I am in Sweden BTW.)
    Also, I have confirmed that old remote is fine by visually looking at IR signal through a digital camera. It shines. (Not visible with naked eye.)
  • max_wenzin Sep 30, 2009
    Ok, have spoken to technician over phone now. He was guessing the main board was going to need replacing and the cost estimate including work and parts would sum up to 3.700 SEK ~= 530 USD.
    That's a bit too much for this 3 year old TV in my opinion. (just to get the remote working)
    So I am looking into other solutions... like buying a new TV.
  • Anonymous Mar 20, 2014
    remote is broken and i need a replacement.i am having trouble getting one as universal doesnt work for this tv
    Genius:
  • 1,112 Answers
Have the technician check for 5 volts on the remote IR Sensor if present the the Remote sensor has failed. Have him replace it to factory Spec's. No need to replace entire main board when the sensor is no more 5 dollars....
Posted on Sep 29, 2009
Testimonial: "Thanks a lot. Seems you've done this yourself :)"
  • 585 Answers
Hi my name is Roety,
I hope I can help you with your issue ,
You most likely have a bad mainboard, the sensor may be cheaper, but I have replaced a few mainboards for this symptom.
If I have helped you with your issue please click accept.
If you have more questions you can still respond
Thanks
Eric
Testimonial: "I sure hope it's just the sensor and that the sensor alone is replaceable. The main board sounds more expensive..."
My original RM-C1502-1C remote [gradually] stopped working. Bought a new one. This worked perfectly for 1 day then stopped working except randomly/intermittently.
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing each button on it at a time; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
May 25, 2015 | Televison & Video
Remote stopped working
clean the circuit board on the remote moisture might be the problem
Aug 14, 2008 | Philips DVD750VR DVD Player/VCR
The sensor on the TV for the remote control seems to have stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Good luck.
Jan 09, 2012 | Televison & Video
The remote control sensor on the TV has stopped working
Regards.
My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
May 08, 2011 | LG 32LC7D Television
The remote doesn't work at all
First, if remote doesn't work, try new batteries......
Regards.
Apr 25, 2011 | LG 32LG30 32 in. LCD HDTV
How do I replace the IR remote sensor on my LG TV?
My LG TV stopped responding to the remote. A very helpful repair technician told me to stick a head phone jack in the sensor jack on the back of the TV a few times to clean out the contacts. Now the remote control works fine.
Jul 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Remote not working on my LG 37LC2D
Try replacing batteries and reprogramming both remotes.
Jul 05, 2009 | LG 37LC2D Television
Remote Sensor
I heard that LG TVs have a problem with the TV not responding to the remote control (there is nothing wrong with the remote control). Hopefully your TV is still under the 2 year warranty. Go to LGService.com and report the problem. They told me that it's a common problem. They need to order the part and let me know when it comes in. (my TV is a LG 50PC1DRA)
The Akai TV might have LG guts inside.
Oct 14, 2007 | LG 42PC1R 42 in. Plasma HDTV
LG 42LC2D 42 in. LCD HDTV Logo
1,100 people viewed this question
Computer Repairing
Computer Repairing
