Question about Microsoft Xbox 360 Console
Will play dvd wont play games
Starts up ok insert a game and message reads > To play this disc. put it in a xbox 360 console.
  • Anonymous Dec 19, 2007
    Put in a xbox 360 game and it trys to read it and it just goes to open tray. You didn't give a solution in this. so a solution would be nice.
    President:
  • 4,402 Answers
Bad dvd drive common for these to have.
Posted on Dec 19, 2007
Wht does it mean when you put a xbox 360 gme in the console and it says play dvd and sometimesa wont read the game discs
When it says play dvd, it just randomly doesn't recognize that it's a game. Press A and you'll enter the game.
When it doesn't recognize the disc all together, I'd suggest cleaning the disc with an anti-static cloth then putting the disc back in.
Mar 05, 2011 | Microsoft Xbox 360 Console
Xbox 360 will not read games or dvd's
Try to insert a straighten paper pin into the hole under the tray if still no go You have to open the cover and take the cd out.
Sep 01, 2008 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
The console thinks the disk is a movie and displays play and pause and chinese looking letters appear on the screen. It won't allow me to do anything
The problem you are facing is of a copied Xbox 360 game you are probably trying to play on a Genuine Xbox 360, these discs are read as a movie disk and it shows as "Play DVD".
When you try to play such discs, it would give you dvd media control bar on the bottom and the message in chinese letters is actually a message asking you to insert this disc in a Xbox 360, which is actually a Modded Xbox 360 that is required
Dec 30, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
May 29, 2009 | Microsoft Xbox 360 Console
Reads games as DVD
Does it happen with all your games or just one and which game
Mar 10, 2009 | Microsoft Xbox 360 Console
Won't read disc's
theres a known problem with the hitashi dvd drive in the xbox 360.
the only solution to this is a home repair job, look up on youtube on how to do this, although this isnt recommended as it voids warranty.
so the best way is definitely just to ring microsoft and send ur console in for repair.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
79 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
