Leaks water inside washer overnight
Sear 11042822202 KENMORE ELITE front loader washer leaks water inside overnight and fills up the inside until it runs on the floor. This is happening intermittent.
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Could be water fill valves ,,try turning them off for a few nights if this workds ..hey presto..if not could be drain too low,, water entering via sink outlet /drain....in this case raise hose..hope this helps you can let me know.....
Posted on Sep 29, 2009
I have a kenmore elite front loader washing machine and the problem is that the rubber gasket ripped causing water leak
Nothing to do there but replace it. Call sears service with your model#, serial# and date of purchase to order one.
Nov 29, 2010 | Kenmore Elite 45986 Front Load Washer
Water leaks into drum and machine intermittantly
The mixing value is leaking. I ordered a new one and will replace it.
Dec 20, 2009 | Kenmore Washing Machines
I have a Kenmore Elite Oasis HE top loader washer; It will start but gives me an LF error.
this is a fault in the water valve control, "LF" means Long fill (fill time exceeeded), so u will need to have the sears guy out to sort this problem out. are the water valves on the wall turned on all the way?
Jul 15, 2009 | Kenmore Washing Machines
I have a top loader kenmore elite washer that is leaking. The service guys have replaced everything from valves, tub ring and the fabric softner dispenser but its still leaking Help
Hi, Did they check the pump seal or the hoses. Does it seem to leak from the front center? Is it leaking while filling or during agitation or spin cycle? Are you getting water every load and is it a little water or a lot?
Please forgive all the questions, I have to ask.
Questions I need to ask in order to assist you as best I can.
Vic
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Water in Drum
replace fill valve under top left rear its bleeding throw it will fix that
Nov 12, 2008 | Kenmore Elite 45986 Front Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
