Question about ION Audio VCR2PC VHS VCR
I have loaded the (VHS) tape and burned it directly onto Disc. When playing the (DVD) disc, the speed of both picture and souns is just a bit too fast. What could it be (I did preselect PAL_B, but am not sure what all the differences are?). thanks for your help. Hans
    Scholar:
  • 64 Answers
If you are in the United States, it should NOT be set to PAL it should be set to NTSC_M here is a site that shows whos what and where
http://www.ihffilm.com/videostandard.html
Posted on Jun 01, 2010
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
Copy from vhs to dvd- want to speed process ???
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
Nov 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Panasonic DMR E20 Produces a line of distortion along the bottom
Sounds like you see head switching from the tape. Most TV are over scanned enough to hide it.
Aug 30, 2009 | Panasonic DMR-E20 DVD Recorder
I just bought and set up the vhs to dvd program but when i coppied the video onto the disc and tried to play ti in the dvd player it said disc error.i made sure i followed the hook up directions.help!
You have either used a disc that is not compatible with your dvd player, or used the wrong file system for the dvd and/or format, have not finalized the dvd recording.
If you use a dvd-r for recording, the disc has to be finalized, regions use different formats of video(UK=PAL, USA=NTSC)
The easiest way to use your disc would be to convert the video to avi format(xvid divx mp4/3) and burn to a disc as data format.
Download ANY VIDEO CONVERTER FREE,
and ASHAMPOO BURNING STUDIO6 FREE .
Use the converter to change the video to avi, use the studio to burn the video as a data disc, you can get up to 14hours per standard dvd(28 hrs on a dual layer). Put the disc in and it will play as a DivX dvd.
Aug 14, 2009 | Computers & Internet
Wont burn to disc
I don't you can record because you are going from analog to digital with out a conversion proccesor. need to investigate. .type in google problem.
Mar 12, 2009 | Philips Televison & Video
Daewoo VHS to DVD converter - disk only plays on the converter
The Disc needs to be finalised. Using the setup menu and disc info you select "finalize disc". I had the same problem.
Jan 12, 2009 | Daewoo DV-T8DN VHS VCR
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Dec 30, 2008 | Samsung DVD-V4600 DVD Player/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
ION Audio VCR2PC VHS VCR Logo
76 people viewed this question
Top ION Audio Televison & Video Experts
Rajendra Singh
Rajendra Singh
 Grubhead
Grubhead
Martin Murray
Are you an ION Audio Televison and Video Expert? Answer questions, earn points and help others
