Question about Kodak DC3200 Digital Camera
My Kodak DC3200 Digital camera has been break the battery jack so i can not instal the battery.
Agent Allan
  • 480 Answers
SOURCE: Digital Camera Battery Prloblem
Hey Frustrated47,
According to the manufacturer a glowing red light either means your memory card is full, or your memory card is set to read only. I would try uploading your images to you computer using a card reader, and if this doesn't work I would make sure that the SD card is not set to the locked position. If neither of these options works I would try cleaning the battery contacts. If none of this works I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 31, 2008
BillB-SA
  • 2761 Answers
SOURCE: I have a Kodak 8.1megapixal digital camera won't charge
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
  • 15 Answers
SOURCE: new batteries last a couple of hours at most in this camera.
for this camera, I think this model is no longer supported by the kodak technical support, they will direct you only in www.kodak.com/go/camerasupport. to solve this try to clean the metal contacts on the battery compartment using clean lint free dry cloth. try to power up the cam with out the memory card. If this will not correct the problem, my advise is to use recomended batteries for this camera. It is recomended to use Kodak batteries because they are specifically design to power up the camera.
Posted on Aug 28, 2009
Neerak21
  • 101 Answers
SOURCE: Junk Kodak Z14854IS digital camera?
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Posted on Sep 25, 2009
SOURCE: Kodak Z740 digital camera
I tried the turn off fixes but they did not help. Finally I got so frustrated I took the camera apart figuring I had nothing to lose. I blew it out with air, put it back together and WA-LA it is working. If you decide to try taking yours apart, be very careful, go slowly. The case is nothing more than thin plastic, just like a cell phone. If you try to force it you will probably crack it. I went slow and had no problems.
Posted on Dec 01, 2011
Need manual for argus dc3200
http://www.arguscamera.com/support/manuals/DC3200.pdf
Apr 12, 2011 | Argus Cameras
Camera Kodak DC3200 Battery door has clips broken. Where can I get it repaired in Australia and what is the cost of this repair, please?
Please check the link below and find the shop close to your place.
Also if the door has broken on the plastic side , you can use instant glue to bond after cleaning the surface and keeping the joints under pressure. Also you can wedge some steel ribs into the plastic to reinforce and glue on top, use soldering iron to heat the steel leads.
Apr 08, 2011 | Kodak Cameras
I need to see a picture of the memory chip for a kodax dc3200
The DC3200 uses Compact Flash cards. You can read all about them and see pictures at
http://en.wikipedia.org/wiki/CompactFlash
Apr 01, 2011 | Cameras
Is there usb connector for kodak dc3200
No, unfortunately you can't connect your camera to your computer via USB cable, only with a much slower RS-232 serial cable. See this illustration and description: http://www.kodak.com/global/en/service/digCam/dc3200/ownerManual/ch052.shtml
P.S. If this helped you to solve the problem (or at least brought some clarification) - rate this solution with 4 thumbs up! But before you would give a negative rating - post a comment, so I could improve my solution to satisfy your needs. Thank you!
Mar 07, 2011 | Kodak DC3200 Digital Camera
Installed new batteries and the camera will not turn on. The camera has been sitting up for 6 mo. with no use. We used energizer lithium batteries.
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
You can even contact Kodak direct and they will send you a free CRV3 battery to test with.
(http://graphics.kodak.com/docimaging/US/en/Landing_Page/ServiceSupportContacts/index.htm)
Oct 26, 2009 | Kodak EasyShare C653 Digital Camera
What exactly is a kodak camera dock? I have a M893 IS kodak camera and having difficulty installing the software so I can transfer my photos to computer - so I thought maybe the "kodak camera jack" would...
The Kodak camera dock provides automatic battery charging and automatic connection to your computer when the camera is "docked." There is also a version of the dock that includes a printer, but I have found the printer to be poor quality and very unreliable. The dock must be connected to the computer via USB, and the Kodak EasyShare software must still be installed. The dock is a very handy accessory, but it will not solve your problem. What might help though is a visit to Kodak.com where you can get a free download of the latest EasyShare software that is correct for your operating system.
Oct 21, 2009 | Kodak Easyshare M893 Digital Camera
My camera is sony type
no I did not fix the problem
Dec 12, 2008 | Kodak DC3200 Digital Camera
Can't get camera connected to computer
have my camera upload my pictures to my computer through pc connect
Jun 21, 2008 | Kodak DC3200 Digital Camera
Kodak digital camera
Camera will not charge through USB interface, only DC input jack or camera dock.
Jun 13, 2008 | Kodak EasyShare M853 Digital Camera
Kodak DC3200 Digital Camera Logo
24 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
