Ghosting With a Brother 5350 & a 5370 DW we are printing on a laset suitable acetate textile, which is flat as paper and is pretreated to accept toner from a laser printer. But now when I feed several pages throuh I get some sort of a ghosting image on the prints. The distance between the original text and the gosting text is : 7,38 cm (2,91 Inch). I have also tested this material in several other laser printers, HP4500, HP2500, OKI 6250, there the problem does not occur...
Muggs01
  • 71 Answers
SOURCE: MFC-7420 GHOST IMAGES
sounds like a bad drumbur also can be caused by a defective fuser.
Posted on Jan 16, 2009
ArmyMason
  • 121 Answers
SOURCE: Blurry printing on laser printer
You have a bad drum. Return the drum for a replacement and you should be good to go.
Armymason
Posted on Apr 01, 2009
  • 55 Answers
SOURCE: Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Posted on Apr 25, 2009
komguy
  • 2306 Answers
SOURCE: HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Posted on Aug 03, 2009
duane_wong
  • 6826 Answers
SOURCE: printer laser b410 print empty page
I would uninstall and reinstall the driver:
http://my.okidata.com/oki-faq.nsf/FAQCentral/77AE0D0F5AEA7EDD85257666004F56C7?OpenDocument
Posted on Jul 20, 2010
Can I print onto acetate paper (clear sheets) with a brother 7440n printer?
Presumably you want to make transparencies. There are Transparencies available specifically for Laser printers and Copiers. Do not use anything else or they will melt around the fuser and wreck your machine. Fixable but expensive.
Oct 09, 2013 | Brother HL-2040 Laser Printer
How do i print onto acetate using an epson sx200; it doesn't recognise any paper... thanks
Some printers use a light sensor to tell if paper is loaded or not. If printing on clear acetate, try loading a regular sheet of paper under it. It should pull the acetate sheet through and leave the regular paper in tray. Since the Epson sx200 is an inkjet printer be careful not to smudge. I would allow a good 5 to 10 minutes to dry. Good luck!
Mar 01, 2011 | Office Equipment & Supplies
Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Apr 25, 2010 | Brother HL-5370DWT Laser Printer
Brother HL-5370 DW printer is wrinkling every envelope that it prints. What to do?
Did you pull down the 2 levers on the back of the computer? I forgot to do this one time and all of my envelopes came out wrinkled. I looked up troubleshooting and realized I forgot to perform that step. Worked great once it was done!
Oct 13, 2009 | Brother Office Equipment & Supplies
Ghosting when using HP CP2025N
Bad drum unit poor fusing or paper type try to print paper type cardstock as type, this increases fuser temp and slows printer for better quality.
-Carl, please let me know if this helps.
Jun 25, 2009 | HP Laserjet Cp2025n Printer
Ghosting on prints
Wrong paper type can cause this, also if it is damp or too thick. Also check that you have the correct type of paper (thickness) selected in the driver. Ghosting can also be caused by a faulty drum unit, since you just replaced it maybe there is warranty left on it?.
May 24, 2009 | Brother HL 5140 Laser Printer
Printing on acetate sheets with a epson dx7400
i had the same problem i solved this by sticking plain whitecopier paper to the direction strip with double sided sticky tape printed asultra gloss photopaper
May 15, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ghost printing when printing envelopes
go to printing properties and try different settings like heavy paper or file folders etc. what happens is the machine is not applying enough heat to the toner to melt it good luck brother sr tech
Jan 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
Colour printing gives ghost image
Are you using genuine Brother color cartridges? If you are, then try different paper (20 pound laser printer paper or plain paper copier paper rather than inkjet paper,) Also, do not use recycled paper. If that does not work, you may need a new imaging (OPC belt) unit, or a new fuser assembly. Check your owners manual about when to replace the imaging unit or fuser. It is usually after 60, 000 prints have been run.
Jun 09, 2008 | Brother MFC-9420CN All-In-One Laser...
127 people viewed this question
jasbo
jasbo
