Question about Dryers
Tower fan will not swing - Dryers
  • darksoul3377 Sep 29, 2009
    tx for ur reply rolingking. But I dun even noe wer the pivot lever or e motor is? =
  • 832 Answers
Check the pivot lever if it is still in place. Remount this
lever to its location. However, if the swinging is controlled by a small motor, check the motor if this is still running. Otherwise, it needs replacement.
Posted on Sep 29, 2009
  • rolando ingking Oct 05, 2009
    The lever is just behind the propeller, and under the motor of the fan. Check this up if you can find one, and e-mail back so I can
    assist you.
Holmes u tower fan. How do I clean it?
Best way to clean most tower fans - YouTube
? 0:23
www.youtube.com/watch?v=PDnPs7AQu_M
May 9, 2014 - Uploaded by slim alee
Keywords; Lasko,Honeywell, ozari, Holmes, newair, crane, Seville, vernado, etc etc. how to open a tower fan ...
Sep 30, 2015 | Tower Dryers
How do I clean a Bonaire oscillating tower fan btf4002
The easiest way to to use pressurized air. Buy a can or use compressed air.
May 23, 2014 | Bionaire Slopeflow 40" Tower Fan with...
My baioniar fan not work properly only swing but not start motor so what can I do . there is no machnic hear that co'z u tel me how ripiar this
I found my own solution for fixing my fan, I took the cover off of the fan by removing the base, and the three screws that hold the cover on, I cold start the fan by turning it on and forcing the blades to turn, But that was the only way it would work. What I found was at the top of the shaft that goes through the fan there is a rubber cap that holds grease it is held on with two screws , The grease in the cup was hard and wouldn't let the fan move freely, So I cleaned out the old grease and put in some new grease that I had here it is grease used for my pool pump motors to keep the seals soft so this grease wont get hard. I put the fan back together and it is working fine. I hope that this works for you. Denis K.
Oct 08, 2011 | Bionaire BT45RC Tower Fan
Tower fan doesn't turn on
see if the timer is set to the desired setting
Jul 20, 2011 | Haier FTP120W FAN TOWER
How to dissamble to clean aloha breeze tower fan model 87001
I just used an air air compressor with a soft rubber tip and went at my two tower fans outside. It took maybe 10 minutes shooting air in from many different points but both fans now work as good as new. If it's been a couple of seasons like mine you'll be amazed at how much blows out.
May 14, 2010 | Tower Aloha Breeze Fan
Grinding noise in tower
Grinding noise in tower If everything on your computer is working fine then it is probaly a fan put your ear in the back of your tower near the power cord and see if you can hear the grinding noise better if you can then your power supply's fan is going out if not its probally one of the inside fans in your tower open up your tower and see if you can find which fan it is if you dont want to do this you should probaly get a tech to look at it it's a pretty cheap fix and it can save your computer from heat dammage
Nov 07, 2009 | Computers & Internet
FTT-R tower fan would oscillate but the fan would not run.
You might have a stripped gear in the tower where it oscillates. Hope this helps!
Jul 14, 2009 | Black & Decker BDTF1010B Tower Fan
Need a replacement remote for tower fan
CALL 1-800-295-4448 THE WILL SEND YOU A REPLACEMENT
GOOD LUCK
Jul 03, 2009 | Tower Aloha Breeze Fan
Tower fan 07586 parts (screws)
I have an Aloahbreeze Tower Fan. The remote control does not work,I put new batteries in and it still does not work. I am disabled and need the remote. It was a gift, as I have no income, so I cannot buy a new Tower Fa. Thank you, Sheila Pike Model No. 84001(FZ25-)
May 29, 2008 | Tower Aloha Breeze Fan
Dryers Logo
88 people viewed this question
Top Dryers Experts
