Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
The interior site stays on and melted the plastic cover. when pushing the "close" buttons manualy the LED display goes out but not the lights. The freezer works OK.
  • 615 Answers
Hi, take out the light bulb and clean the inside after disconnecting the cables from the AC. making sure that the insides are very dry. The inside switch may be defective and does not turn off you may need to replace it the issue is between the light connection and the switch so I will check these two places first.
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Posted on Sep 29, 2009
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Our 2005 dodge diesel quad cab 4x4 has a interior light that stays on nd drains the battery steady !!
either you have a door switch thats stuck or bad,suggest until you figuer out which,remove the bulb from interior lighr that stays on,a push button may have gone bad or simply stuck in on position. removing the bulb will stop the battery drain,but will have no inside light from that bulb when you remove it. the plastic cover on that light should just pop out with a straight screw driver when pryed open from one side or other of plastic cover. look for an indentation or slot on side of plastic cover to remove that cover. hope this helps and thank you for choosing fixya.com
Jan 03, 2011 | Dodge Ram 3500 Cars & Trucks
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
Inside lights do not go off when doors are closed
Good day,
All refrigerators have light switches, that depress and shut off the lights when the doors are closed.
First, make sure the bulbs are left out. I would replace all of the light switches because of the newness of the machine.
They are easy enough to replace, and you can purchase them at any appliance parts house or a Sears service facility.
They pry out, and may be destroyed on removal. Unplug the machine.
After connecting the wires, the new ones just push in.
To test, close the doors slowly. The lights should go out just before the door closes.
Some states have what is called "Implied warranty of serviceablity". Which means what should a consumer reasonably expect irregardless of the warranty limits.
You might want to contact Sears and express your opinions regarding this matter, and if they'll consider making you whole.
The above paragraph are my thoughts only. They in no way reflect the law, Sears policy or liability or this site's policy.
Dec 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Dec 10, 2009 | LG LFX25960ST Stainless Steel French Door...
The interior lights stay on and the door ajar light is on when driving. the interior lights stay on when you shut off the car thus running the battery down. It happens about 70 percent of the time and when...
Find the lamp push button on each door.
Open one door, and only one door (or tailgate).
Push the lamp button IN at that door. If light goes out, then that particular push switch needs adjustment or replacement.
Cl;ose door and open another door. Push button IN.
Keep doing this until you find faulty door push button.
Which door was it?
Sep 24, 2009 | 1998 Lincoln Navigator
HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
Jun 12, 2009 | LG 22 Cu. Ft. French Door Refrigerator,...
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
49 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
