Question about Viper Security and Remote Start System (basic install included)
My viper 350hv isn't as sensitive and led blinking
My viper alarm is not as sensitive as people say it is and its sensitivity is as high as it goes? where should i place the brain/shock sensor?
and when i disarm the led blinks 3 times when its supposed to be 2 times whats wrong?
2 Suggested Answers
deadrock69
SOURCE: Viper 5901 Starting issues
i need to adjust the time that it waits to start for my glow plugs in my 2001 ford excursion diesel 7.3. I need it to wait another 10 - 12 sec.
Posted on Jan 07, 2010
My viper alarm system when armed and disarmed there is no sound from the speaker
Either the system is in valet or, the chirps have been deleted or, the siren is broken.
If the LED is on solid the system is in valet. open the door, press lock, unlock, lock on the remote to remove valet.
Press and hold the lock button. This activates the car finder/panic. The siren should begin to wail. If it does, the siren works. If it doesn't and all you see is the aprking lights flashing the siren is defective.
Mar 04, 2013 | 350 HV ESP Security System 350HV ESP
Car alarm doesn't go off with light impact
bumping or rocking the vehicle is not an impact .
Oct 04, 2017 | 350 HV ESP Security System 350HV ESP
How do I adjust the sensitivity of my alarm? I can slam the tailgate and it will not go off. Also, I can activate my remote start and it will start and run, BUT, oftentimes when I hit the open door...
To adjust the alarm sensitivity there is a sensor usually on the steering column with a plastic screw that can be turn to adjust the sensitivity. To change the setting you will probably need the manual for the alarm and there is a wire with a small button on that to program settings for alarm sound or remote start start and stop time.
Apr 20, 2017 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My 350hv just shuts off randomly. I can arm it and come back later and it is off and my doors are unlocked!
Sorry, but it is my opinion that car alarms are really, really foolish.
Cars are extremely hostile environments for delicate electronics.
Adding alarms is begging for problems that will leave you without a car.
If you lock any valuables in the trunk, out of sight, there is no reason for an alarm. All an alarm will do is either fail and prevent you from driving, or fail and get you a ticket for a false alarm.
Jun 20, 2010 | 350 HV ESP Security System 350HV ESP
I have a jeep with a viper 5900 installed when
small box under or around steering column. may have to remove panel under steering column or get lucky and may find it if you lay on your back on floor of driver area. look up underneath for a box 2" x 2" x 1" black box with an l.e.d. light on it. arm the vehicle and bang on steering wheel and look for the led light to light up and set off alarm. light will be red or green and will only light up during vibration.
find adjustment screw on it and turn counterclockwise.
Dec 31, 2009 | 5900 SST 2-Way Security System / Remote...
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
350hv did not come with a installation manual I I
their award-winning (Aernt they all?) Technical Support department can be reached toll-free at 1-800-753-0600, the guide is here on pdf - http://www.directeddealers.com/manuals/og/viper/G426V_07-05.pdf
but installation info is sketchy. Hope it works out well, great alarm system.
Jun 28, 2009 | 2001 Toyota Tundra
Alarm System
No it won't reset your alarm system. As part of the bit-writer program, anything you set or change in the alarm menu will remain the same. The only thing that can happen is if you have a DEI 520t back up battery, it may trigger the alarm upon re-connecting. No biggy.
Feb 25, 2009 | Viper Vehicle Parts & Accessories
I have a viper 5900 car alarm installed with remote start.
Look under dash for a small black box with wires coming out of it, about 2 or 3 inches rectangular.. there should be one or two screws on it. Look to see if it says which direction to turn for sensitivity. As far as not receiving, you need a new antenna, this is covered under warranty through DEI either bring back to where you purchased or look online and see where the closest dealer is to you...
Jan 28, 2009 | 5900 SST 2-Way Security System / Remote...
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
316 people viewed this question
Top Viper Home Security Experts
Kevin Daniels
squeely
Are you a Viper Home Security Expert? Answer questions, earn points and help others
