Question about Goodman GDS80904BNA Open Flame Heater
Furnace won't fire up , induction motor comes on but no ignition. Get blinking lites that indicate problem with presure sensor, replaced it and still get same indicators. ANy ideas. I am leaning toward new board,
  • Dennis Blackwell
    Dennis Blackwell Sep 29, 2009
    Thanks - but we are not getting the hot surface ignitor to come on - just the induction motor and the blinking lites = saying that the presure switch id open and then that it is closed. we replaced the presure switch- get the same messages.
  • Dennis Blackwell
    I don't have ignition , all we are getting is the induction motor runing when the thermostate calls for heat. The ignitor does not lite up, we get blinking lites telling us that the presure switch is open then we get another message that says it is closed. We replaced the presure switch and got the same error messages. There is no corrosion the unit is only about 2 years old. It was working fine last May the last time it called for heat.
  • 3,741 Answers
If after replacing the pressure switch its showing the same problem then try this --------- pull the exhaust fan end of the hose that runs from the pressure switch to the exhaust fan. Then snipoff about 1/4 - 1/2 inch off the hose, and attach the hose back onto the exhaust fan and check out. ------------- if still the same problem then is the faulty board which needs replacement. ----------- you can get new board from www.repairclinic.com or from www.partsselect.com ----------------- this will help.please do rate the solution.thank you for using fixya.thanks.keep updated.
Posted on Sep 29, 2009
    President:
  • 1,462 Answers
If your igniter comes on but no ignition, that eliminates the possibility of a bad or clogged pressure switch, high limit or flame rollout switch.
This issue may be due to one of the following reason
1)control board must be gone bad,
2)gas valve going bad.
3)some loose, corroded, or faulty wiring.
Before the igniter comes on the furnace does a self diagnostics to ensure everything is working, or the furnace will not make it to the igniter sequence.
Induction motor, pressure switch/s, limit controls are closed…then comes on the ignitier, gas valve opens, pilot runners and burners ignite, flame sensor detects the flame, blower comes on and all operations are working.
Checking all the three possibilites would solve your issue..
Please leave me comments, if you need furthur assistance
RNJ VINODKUMAR
  • Vinod Kumar
    Vinod Kumar Sep 29, 2009
    Even though you get those message, Actually the error is due to
    Any one of these must be wrong, Please check this and tell me
Induction fan comes on ignitor wont ignite
If the igniter turns orange and the gas fires for only a second or two then your heat sensor needs to be cleaned with sand cloth, if it does not turn orange then your igniter needs to be replaced.
Jan 17, 2015 | Amana Gas Furnace 90% Afue 45000 Btu...
My rheem gas furnace got red button that keeps griping what can I do.
The red button that keeps tripping is probably the rollout sensor just above the burner assembly. When this rollout starts tripping, it means your flue gasses are not being drawn out by the induction fan motor. If your furnace is a few years old, the fan blade has probably rusted out and is not moving the flue gas. You will need to get a new induction fan motor. While you are checking the induction fan motor, it is a good idea with everything torn apart to check the condition of your heat exchanger. When the induction fan blade rusts out, it is a good indicator the heat exchanger may need replacing also. So do yourself and favor and check it out for rusted out welds and the like. You will probably need an experienced hvac tech to make the furnace repair.
Hope this helps.
Dec 31, 2014 | Heating & Cooling
Lennox g26q3
electronic ignition or pilot type? assuming electronic ignition, check the airflow sensor for dirt in the peto tube, or a defective sensor, if you hear the high voltage click but have a failed ignition chec that the pilot is being lit, and that the thermopile/infrared sensor is good. one of those is your problem.
Mar 23, 2014 | Heating & Cooling
Ignition failure.
if furnace fires up then immediatly shuts off check the flame sensor. make sure it is sitting far enough inside the burner box and has proper continuity. if ur getting ignition failure without having furnace fire up, check proper voltage to hot surface igniter, continuity within igniter
Dec 05, 2013 | Heating & Cooling
Ignition problem with furnace
hi igniter could be in the wrong postion or its not heating up all the way down or its got a crack in it
Jan 22, 2010 | Heating & Cooling
Armstrong furnace ultra 80sx doesnt always lite on first try,service repair man replaced smartvalve,sensor and igniter he says its ok if it doesnt always lite on the first try ,sometimes it takes three...
Sounds like your gas valve is sticking. Your repair man is somewhat correct by meaning that the furnace will attempt to start 3 times before going out on "Lock-out". The furnace is reaching it's expected life and you will start experiencing more frequent issues with it. Check into some of the incentives to get a replacement with a higher efficiency rating. The newer units have greatly improved in performance as well as comfort.
Jan 13, 2010 | Heating & Cooling
Hello I have a goodman gas furnace
On a call for heat, the 24 volt thermostat2.gif sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the ignitor does not energize (bad control, bad ignitor), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not lite (dirty pilot), the burner does not lite (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Most newer furnaces will have a diagnostic center or control built into the control module. You may be able to view it as it is running thru a small viewing port. Some models will require the removal of an access panel prior to finding it. On the reverse of the access panel, there will be a diagnostic chart that will aide you in understanding any error code recorded (usually a blinking light).
Oct 18, 2009 | Goodman Heating & Cooling
Bad control board?
This is a good one! I would check for a blocked vent or intake pipe first. Also check to make sure the condensate lines are free of moisture or debris. What is the code for three blinks?
Oct 11, 2009 | Goodman GMS807034ANA Heater
My Amana Gas Fired Air Furnace (80) failed to come on with warm air. Blower works but cold air only? Is there an obvious problem here?
first, clean the flame sensor, does the draft motor come on?  could be ignition control board failure
Nov 15, 2008 | Amana Heating & Cooling
Goodman ac/gas furnace unit mdl. # gmp075-4
i HAD THE SAME PROBLEM, TURNS OUT IT WAS THE FLAME SENSOR, CLEANED IT, AND ALL WAS GOOD
Nov 27, 2007 | Cozy (W352E) Heater
Heating & Cooling Logo
332 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
