Question about Palm Zire 31 Handheld
Touch screen will not respond
Have not used my Zire31 in a while and have found that the touch screen will not work. I did a hard reset and then the touch screen began to work..now onto the next issue. Once I got the touch screen working it came to the Digitizer Screen and continued to ask me to "Tap the Target". The target moved from one corner of the screen to the other, but never went to the next screen. I Did this target tapping for a full minute. Is it suppose to go this long? Please help
  • 12 more comments
  • jaydubya11 Jan 07, 2008
    my palm has the exact same problem what do you do to fix it?
  • WML6067 Jan 16, 2008
    I have the same problem. And many others have too. I really want to know how to fix it.
  • sdb2go Feb 04, 2008
    Have the same problem touch screen not working, did a soft and hard reset, when target came up, didn't move from lower right corner and did not respond to stylus. Can anyone help.
    thanks
  • Anonymous Mar 04, 2008
    i opened my zire box stylus is not reponding plzzz suggest
  • Anonymous Apr 18, 2008
    My touchscreen doesn't respond. Did a hardset, tapped the center of the target, it targets just bounce back and forth and I never advance to another screen. Is there a fix for this?
  • Anonymous May 15, 2008
  • mlhoney1 Jul 27, 2008
    I have tried both hard and soft resets. Still having trouble getting out of tapping the targets. tried solution offered. no joy.
  • auscarr Aug 17, 2008
    same problem here
  • kdzire Oct 09, 2008
    I've got the same problem. I can get to the hotsync screen, but cannot tap the hptsync button. Is there a way to force a hotsync from the Palm Desktop or using the toggle keys on the zire 31?
  • evipipsqueak Jan 13, 2009
    I have this problem too. When i start up my palm it goes to the digitizer screen. The "tap the target" keeps going and going. I continuously hit it over and over and it doesn't move on to the next screen. It works when you hit it and moves to the next target (from corner to corner). But it never gets past this screen. I have tried the soft and hard reset. I have erased everything off of it and it still wont get past that part. Any ideas please? thanks :)
  • edpatino59 Feb 03, 2009
    the first time I said do not erase, and now after the hard reset is not asking me again and the screen still does not work
  • Anonymous Feb 06, 2009
    just got my zire 31 today after buying online. did i get the big rip off? okay so I reset while holding down the power key. now i bring up the menus but the stylus will not work - I CANNOT CLICK onto anything!!!! HELP
  • johndins May 21, 2009
    same as amm40
  • Anne Moorehead May 11, 2010
    Have not used my Zire31 in a very long time but have kept it charged up. I did a hard reset and the screen came on and just said Palm Powered but none of the keys work, the touch screen won't work. HELP!!!!
I had the exact problem as you, and was at my wit's end and ready to throw my Zire into the trash can, but decided to give it one last ditch effort by getting in touch with Palm tech support. Boy am I glad I did, because the solution was so easy: what you need to do is hold the power button while you do the hard reset (in the back, using a paper clip), but the key to this step is to keep your finger on the power button for a full 30 seconds. When I tried this same process before, I experienced what you are experiencing, but when I help the power button on for 30 seconds, just like the tech instructed me, it worked on the very first try. It was so easy and it fixed the problem. Give it a try!
Posted on Feb 01, 2009
I had the same problem today. My digitizer would not respond at all despite numerous attempts at hard resets. Finally, I held down the power button while doing a reset (inserting a bent paperclip into the reset hole in the back) and when I let go of the power button I got a message saying "erase all data?" Knowing that my Zire 31 was backed up, I answered yes and the machine reset itself as if it was a new machine out of the box with factory data.
The digitizer worked perfectly!
I then did a hotsync and got all my data back.
Posted on Jun 01, 2008
Yes I had the same problem even after a hard reset and cleared all data. My unit lives in my shirt pocket under a fire resistant suit we are required to wear so it spends many hours every workday in a sweaty hot humid area. I ended up warming unit with a hair dryer intil the case was warm to the touch and did another reset after it cooled off and everything came on as it should.
Posted on Jul 27, 2009
Hard reset with a 30 sec power button hold has not worked, screen still goes into perpetual calibration mode when it comes back up.
Posted on Jun 29, 2009
Thanks!
Posted on Apr 15, 2009
Same here wtf
Posted on Mar 11, 2008
My palm has the exact same problem what do you do to fix it?
Posted on Mar 04, 2008
The clue here is the 'after a few years' bit. palms have a rubber spacer between the TS and the front plastic which prevents the plastic from touching the screen. With age however this spacer gets compressed and the plastic tends to touch the screen and hence stop working.
The solution is equally simple. Open up the palm and seperate the screen from the front plastic. Cut a 2 thin thin strips (say 2mm wide and as long as the screen) off the edge of a visiting card and place it on the now squished rubber spacer (looks like glue) on the inside of the front plastic, one on each side. The edges of the touch screen are not touch sensitive and the paper must press exactly here. Reassemble the palm making sure the paper is well inside and not visible from the outside. The paper may be only 0.1mm thick, but that is enough to keep the plastic from pressing the screen.
Posted on Aug 08, 2009
My HTC Touch's screen is not responding to anything i do other than button presses... Is there anyway i can recalibrate without hard reseting my phone
the touch screen of the phone you are using is weak and it is not responding properly again.
in ther to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jun 17, 2010 | HTC Touch Cellular Phone
My iphone wont respond to touch i cant use it
try hard reset (hold down the power button and the central button until you see Apple logo on screen). If this wont help then use RESTORE.
Aug 25, 2009 | Apple iPhone 3G Black Smartphone
Touch screen won't respond / hard to program
Hi
Try to run the Touch Screen Test(by going into Diagnostics) this will check that the touch screen is calibrated and accurate. If it still doesnt work then go to Initialize GPS this will Reset the unit and will reacquire the satellite signal.
Note: Previously saved satellite data will be reset and reacquiring the satellite signal may take 15 minutes or more.
Please revert for any clarifications.
A Fixya Rating would be appreciated if you found this solution helpful.
Thanks
Rylee
Feb 16, 2009 | Magellan RoadMate 300 GPS Receiver
My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
Feb 12, 2009 | HTC Touch P3450 Smartphone
Touch screen do not respond
At times, Touch screen does not respond and phone cannot be unlocked by no means, Problem do not get solved even after restarting phone, removing battery & reinserting etc.. This happend typically during nights when the phone is not used and in the morning, touch screen does not respond to do any activities. after installing a software i had a hard reset, after that my tuch screen did not work.please help meeeeeeeeeeee ! !
Jul 30, 2008 | i-mate JAM Pocket PC
Touch screen not responding.
Is there anything on the screen?
try to perform a cold reset by plugging the battery out
Jul 22, 2008 | HTC Touch P3450 Smartphone
Touch screen & key board with stick does not respond
try aligning the screen...
settings > screen > general > Align Screen
If that doesn't work try hard reset... i.e.
press the two soft keys and the reset button using stylus...
If its still not working do soft reset:
settings > system > Clear storage
but remember to take back up of phone before doing this..as it will erase all your data...
and do tell me if it worked or not...
Jun 25, 2008 | HTC P3300 Smartphone
could you explain in detail what s happening with your phone??
u said that ur phone cannot be unlocked...but then u say that it happens typically during nights...do u mind elaborating?
May 10, 2008 | HTC P3300 Smartphone
Touch screen not working...
Hi guys,
i post this solution for those wo will be in the same situation in th next future. I had the same problem with my HTC TyTN (Herm 200). The touch-screen was simply not working. I read many 'solutions' on the net but none worked. I did not try the hard-reset because i was convinced this is not a software problem, and resetting the WM5 will not help. So i brushed the corners, looked for small particles which were pressing on the cover of the touch screen. but it did not work. finally i found one post (i don't remember where exactly) where a guy used a credit card and pushed it all around the touch-screen under the metal case (a bit harder). i tried it and it worked. i pressed harder especially in the lower part, above the buttons. and simply it worked ! no problem since then.
Feb 26, 2008 | HTC TyTN Smartphone
Palm Zire 31 Handheld Logo
1,772 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
