Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
My tv is turning everything purple like it is
I was moving stuff in my rom and when i turned my TV on in its new position it was purple but faded to blue at the edges of the screen and white/grey in the middle. its an old TV but it was workinjg fine this morning?
    Genius:
  • 1,112 Answers
Hello :
The problem is your color purity is off. The earths magnetic poles cause this to happen on all direct view televisions, when you move a television or turn it from its usual viewing spot. You may have noticed a thump sound when you first cut on the television after its been off for a while, this is the televisions degaussing circuit mixing the color phospers in the picture tube. One way to clear this is to turn off the set for at least 20 mins and turning it back on this usually clears the purity. Have you ever had a older computer monitor and it had a button on it that says degauss an press it and you see a rainbow of colors then the screen goes back to normal. Well your television also has one too but does it when you first cut on the television you can't see the rainbow effect because the screen is still dark at this point.
If this does not work have a technician come out and degauss the set for u manually, using a degaussing coil.
Hope this explains your problem,,
Please leave a comment for futher assistance.
Delhielectronics@live.com
Posted on Sep 29, 2009
My picture fades out, I have sound can't change the channels?
soundslike you need a new TV or get this one repaired .
Aug 08, 2016 | Televison & Video
RCA l32HD31YX12 white vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 02, 2017 | RCA L32HD31 32 in. LCD HDTV
Purple picture with sound
Hi, that sounds likes a degaussing coil problem,or a magnet have come to close of the tv, you will
needs a picture demagnetizer where you gone put it on the picture tube and making circle on the tube and walking back at the same time you still making circle and enlargin the circle at the same time you walk after 10 feet about turn off the demagnetizer,
that should bring at the normal color; if not thats
inside ,look for a positor or thermistor to replace
and try to dont turn the tv when the power is on
thats affect the degaussing process it work only when you start the tv on for few second..
good luck and hope that help you
have a nice days
Mar 13, 2010 | Televison & Video
Xbox 360 is showing purple lines on tv screen.
Hi...
Pull out the video cable from both ends.
Re-attach and try again
Let me know
Jan 18, 2009 | Microsoft Xbox 360 Console
Sony 51" wide screen rear projection tv
Looks like like you have got some burnt fuses near the D-board. What we are looking for are burnt ceramic fuses. Should cost you around 10$for 8 of them. I advice you replace all 6 and then check if its alright..
Jul 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Colors are messed up
the deguasser in your tv may not be working right..or the magnets in the corner of your tv has moved....it can be manually deguassed but a tv shop would have to do it..
Jun 28, 2008 | Sylvania 6427TE 27" TV
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Picture and Sound fade in an out
4 years? Sounds like the lamp compartment is overheating. Take the covers off the right side (To Access the lamp) and the whole panel on back. This will give you access to the lamp assembly and fans. Get a can compressed air and blow everything out. Try to blow everything towards the right side and pull the lamp and do it seperatly.
Sep 09, 2007 | LG RU-52SZ51D 52" Rear Projection...
Purple tint on screen
Color splases can show up when the sets are move from one location to another or when they have been dropped while moving it,another reason is when a speaker is placed to close to the tv.The tv has an internal demagnetizer witch gets activated when you turn the tv on,I suggest to unplug the unit for about 15 minutes and then plug the unit and turn it on,If the unit was dropped this problem might not be repairable.I hope the information helps .
Oct 02, 2006 | Symphonic SC519DD 19 in. TV/DVD Combo
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
205 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
