Question about Umax AstraPix 570 Digital Camera
Cannon 30 D
Cannom 30 d error 99 from cannon 30 D
  • ebabure May 11, 2010
    Here is your Solutions
    » Canon » Fuji » Kodak » Nikon » Olympus » Panasonic » Samsung » Sony
    chiria44
What is the solution of cannom printer 145 error 2 & 7
Please go to this website and read it carefully:
http://tricks-collections.com/reset-waste-ink-counter-canon-pixma-mp145/
Jan 12, 2013 | Office Equipment & Supplies
I have cannon EOS 400D problem is error 99, some times after shooting
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Have a good one!
Apr 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
HI I have a cannon eos digital SLR. When I try to take a picture error 99 appears on the screen. I do not know how to correct it. Will I have to send it back to the cannon company? Is there someway I can...
Error 99 and believe me I've been there is Canon's catch all error code cause if the camera can't figure out what's wrong it goes to Error 99. Canon doesn't release any information directly towards error 99 due to several different causes. That was the bad news. The good news or at least the better news is that most of the time error 99 is caused by dirty contacts between the camera and lens. At least this is the problem I'll address in this solution.
You will need a new pencil with a red rubber eraser, make sure the camera is turned off, remove the lens from your camera and put a body cap on. If you do not have a body cap lay the camera lens mount face down on a clean lint free surface. Take the lens and hold as vertical as possible with the rear lens element facing down and turn the lens body so you can see the gold contacts. Use the red rubber eraser to gently clean the contacts. Make sure they are clean and all rubber dust is removed from the lens and contacts. on the lens you may use a little puffer/blower or a lens cloth not a tissue. Do not use a liquid cleaner. Once you have finished the cleaning of these contacts either put a rear lens cap on or set the lens where it is not going to get knocked over sitting on a clean dust free surface with the contacts down. Now take the camera and as much as possible keep the lens cavity pointing down to eliminate any rubber dust from entering the camera, clean the contacts again gently with the rubber eraser clear the dust with a lens cloth not a tissue DO NOT use a puffer/blower at this point because it will only blow the dirt into the camera. Once you are satisfied that area is clean reinstall the lens make sure it's locked and turn on the camera. You should be "Good to go". Well lets hope so anyway. Error 99 can also be a problem with third party lenses like Tamron, Sigma, Tokina not having the up to date electronics to match your camera properly Error 99 can also be caused by requiring a camera firmware update but for now lets just go with cleaning the lens to camera contacts.
Jan 09, 2011 | Canon PowerShot S410 / IXUS 430 Digital...
Cannon eos rebel? will shoot a few photos then just stops saying error 99! why? can it be fixed?
try and remove the battery and wait for like a minute, after that if it does not work then try and clean all the contact on the camera.
Oct 25, 2010 | Cameras
My cannon rebel eos DS6041 displays error 99 when
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
Jun 01, 2010 | Canon Digital Rebel / EOS-300D Digital...
Cannon 400 error message 99
Error 99 is a NONSPECIFIC error message. It may be a lens problem. It may be a shutter problem. It may be a battery problem. It's Canon's way of saying "Something happened, and we don't know exactly what, but we know it isn't right".
You're going to have to try to narrow it down by using fresh batteries, trying different lenses, trying different shooting modes, shooting wide open in Av, manually focussing, turning off IS if you have it. In short, if it happens regularly, try to identify what you're doing when it happens and how that differs from when it doesn't.
But don't expect somebody else's solution to work for you. Their camera may have a different problem.
Apr 10, 2010 | Canon Cameras
I have a Cannon Rebel XTI and i keep getting err 99
Make sure your firmware is up to date. The current version is 1.09 which did address a problem with live view that could cause error 99.
Here's the link http://web.canon.jp/imaging/eosd/firm-e/eosdigital4/firmware.html
Also try removing your lens and putting it back on. Sometimes it is a bad connections between the body and lens that can cause this error.
Jan 27, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Cannon Eos 400D Err 99?
Error 99 is a NONSPECIFIC error message. It is almost always associated with the LENS. I first got this error on my EOS 20D whei I tried to use an older Sigma zoom lens (7 years older than the camera). I don't use off-brand lenses with my Canons. Try removing the main battery first followed by the time & date battery which is hidden in the battery compartment beside the main battery. This will reset your camera. Good Luck!
Nov 30, 2008 | Cameras
My camera is making me sad :-(
This was taken from another site:
My camera displays “bC” or “Err 99” when I try to take a picture. What does this mean?
BC is an error condition in EOS film cameras, and means one of two things. It either means “battery check,” so try putting in a fresh battery, or it’s a general error condition of some type. If the battery is fine, have a look at the previous section for things to check, especially dirty lens contacts or lens compatibility problems with Sigma lenses. Error 99 is essentially the same error condition as BC, only on EOS digital cameras. The EOS D30 also had error codes 09 and 10, which are similar.
I hope that info helps.
Good Luck!
Apr 26, 2007 | Cannon Canon i960 Photo Printer
Umax AstraPix 570 Digital Camera Logo
22 people viewed this question
Top Umax Cameras Experts
Starnley Johnwells
Starnley Johnwells
Jax Planet
Jax Planet
Faiz Mohammed
Faiz Mohammed
Are you an Umax Camera Expert? Answer questions, earn points and help others
