Question about Epson Stylus DX6050 All-In-One InkJet Printer
The paper does not feed into the printer. Roller start to pull in the paper but one side is blocked causing to start to enter at an angle and the jamming after 1cm in.
  • 330 Answers
Please clean the paper pickup roller and check paper quality
Posted on Sep 29, 2009
HP LaserJet 4 Plus printer, as the paper is starting to feed into the printer from the MP tray the paper on the left side pulls in crocked and therefore causes a paper jam. Pick up roller and seperation...
There is something blocking the paper path.(Like a paper clip or something). Remove the toner cartridge first, then use a file folder or thin cardboard to push the object out of the way. Put the toner back in and try printing again. Good luck !
Apr 03, 2013 | HP LaserJet 4 plus Printer
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
When Copying or printing the paper does not feed
open the front cover pull out the cartridge and you see paper feed roller it is rubber. Clean paper feed roller with cloth and water or alcohol.
Jan 24, 2011 | Samsung SCX 4521F All-In-One Laser Printer
My Brother MFC8220 Keeps jamming the paper as it starts to enter the drum, is this a feed issue? or a Drum Issue? It appears to feed from the tray correctly, but then starts jamming as it enters the drum.
Using a cloth damp with water clean the feed roller. You will see it when you pull out the paper tray. If it starts feeding good it was a feeding prob.. If it keeps doing it look at the leading edge of the jammed paper for any signs of dings or bends. if you find any paper damage look in that area for what is causing the damage. Thank you, Steven 805-520-3003
Jul 26, 2010 | Brother MFC 8220 All-In-One Laser Printer
My paper will not load it keeps jamming right away. I am unable to print anything, because it will not feed properly in to the printer. The paper is pulled in slightly on one side only; my right hand side...
Hi ,
This problem may be due to many reason . Paper feeder rolls problem mainly. These roller may be dirty . Clean this roller using moist cotton with Cleaning liquid such as spirit or petrol or very simply Nail polish remover. Clean these roller properly to remove dust or any other material stick on these roller. This will resolve the issue. If this problem still remain continue then this problem is due to alignment problem of the roller. Contact Printer specialist for proper alignment.
Oct 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper will not go thru printer why ?
Printers usually jam or block paper for the following reasons:
There is a small piece of paper somewhere that is stuck.
The rollers are worn out and are too smooth to grab the paper.
There is something mechanically blocking the paper path, pencils, paperclips, etc.
Paper is wet (high humidity areas can cause this.
Paper is too thick, is being re-used or has bent edges.
Paper guides are set too far apart and the paper enters at an angle.
Broken parts. Usually caused by someone forcefully removing a paper jam.
If you have tried all of the above let us know and we can go from there.
Jun 16, 2009 | Office Equipment & Supplies
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
Paper getting stuck
the reason the paper is going in sideways is because one feed roller has more pressure than the other
try cleaning the rollers with alcohol and cotton cloth
If that does not work remove the paper tray t
take your fingers and see if the feed rollers turn freely or turn in only one direction( some rollers are half moon and only turn a half turn)
Just try to make sure that the roller that is not working is in the same position and turns the same as the one that does feed properly
Jan 04, 2009 | Office Equipment & Supplies
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Epson Stylus DX6050 All-In-One InkJet Printer Logo
140 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
