Question about HP PSC 1315 All-In-One InkJet Printer
Faulty ink cartridge
I have had the same problem. I took my ink cartridges back to shop and they tested them and the colour ink cartridge came up as faulty, so they changed it for me and have now been able to print. So I would suggest you try that.
  • 51 Answers
SOURCE: Problems with the hp c3180 all-in-one printer
Did you clean the contacts inside the printer as well as the ink might be built up where cartridge contacts touch the printer contacts in the housing. You have to be quite careful here as there is a small metal spike which grips the printer and you do not want to push this into the contacts in the housing. Just get some damp tissue and rub it over these contacts to clean up any residual ink( turn off the printer first)
Fred
Posted on Jun 15, 2008
  • 684 Answers
SOURCE: Install cartridge missing on Deskjet 6940
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Posted on May 27, 2009
SOURCE: cartridge 57 failed
Brenda Walker on August 18, 2009
I think I may have solved this problem. What I did was take out the #56 cartridge and hit the print button. It started to calibrate and then said it was printing on reserve or something? Yup, it printed with only one (#57 cartridge). After that, I stuck in a new #56 cartridge and so far so good for it only happened yesterday.
I hope this solves your cartridge #57 failed problem. Let me know if it does.
Aloha from Hawaii
Posted on Aug 19, 2009
SOURCE: HP Designjet T610
NECESITO UNA SOLUCION PARA MI PLOTTER T610 CODIGO DE ERROR 22.1:10
Posted on Nov 14, 2009
don_farr
  • 1018 Answers
SOURCE: HP 1050c....Hi, i am getting error on display for
Are you using HP factory new cartridges or some third party cartridges or even wores a refilled cartridge?
80% of the time, that's the cause of the failure.
Don
Posted on Feb 24, 2010
Problem With Kodak Colour Ink Cartridge I bought a Kodak colour ink cartridge as it was saying replace colour, l installed it but it was still saying "replace colour" I thought maybe the cartridge cou
the kodak system uses a countdown system that assumes you use a certain amount of ink re sheet regegardless of how much ink you accutualy use, the counter system starts everyt ime you turn the printer on, so the only way to extend the life of the ink is not to turn the printer off netween use, which the domestic useres do not of course do what i did throw the printer away and get a new one not Kodak sh*t
Mar 28, 2013 | Kodak Esp 3250 Allinone Multifunction ( ...
HP6180 Printer. I keep getting an error message, Ink cartridge em
some cartridges are charged up ( have a chip fitted to them )
If the chip is not charged to tell the printer it,s full of ink. this will cause the problem.
have you tried. unplugging the printer from the mains. then powering it back up.
also try using the printers own software to add new cartridges et,c.
you could also try re-installing the printers drivers/software if you have it,s instalation disk.
Mike @ Compurepair.
Jun 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Canon ip 1880 - colour cartridge problem
no if ur filling the catridge more times the printer going to damage
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
May 27, 2009 | HP Deskjet 6940 InkJet Printer
Says to check color cartridge
The cartridge could be faulty. Try replacing it with a new colour cartridge. Are you using generics?
Brian
Jan 11, 2009 | HP PSC 1610 All-In-One InkJet Printer
I replaced the ink cartridge in my HP PSC 1400 all in one series and it is still saying check ink. I also took out the color cartridge but didn't replace it because I never make color copies. Does the...
in your printer u need both cartriges inseted in the printer.u cannot install 1 in your printer it will not function.
clean the brown dotted circuit of the cartridges and check out if it is working.or the replacement of both the cartridges is necessary as the message is replace the ink cartridge.
if u get a message of replace black then u have to replace black.
if the message is replace colour the u have to replace colour.
if ust replace cartridges then replace both 1 by 1 .it will work properly after replacement.thanks.
Nov 14, 2008 | HP Office Equipment & Supplies
Canon Printer Picms MP450 Error 6500
They don't like re used cartridges.
I would purchase a new printer as they are not economic to repair.
Feb 27, 2017 | Canon Pixma MP450 All-In-One InkJet...
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Colour Cartridge
hi check your cartridge number are ok , clean the pin points of the cartridge and carridge pins of the printer if not works , try another cartridge if not works than may be carridge faulty , carridge data cable faulty, or logic card of the printer go to your service center or any repairing shop .
Mar 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
