Question about Nokia N95 Cellular Phone
How do i connect motorola h700 bluetooth to my nokia n95..am not able to pair it even after several attempts
I would like to transfer my bluetooth H700 to my new phone blackberry bold phone.
Posted on Apr 20, 2010
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Won't detect Motorola H700
Hi David, I want you to go to this link for your nokia E65. Click the link.
http://europe.nokia.com/link?cid=PLAIN_TEXT_119729
On the left side of the page click Demos
When the demo window opens click, Select Demos button.
Scroll through the list until you see Sending Via bluetooth.
Follow the interactive instruction to connect to your H700.
You'll need to set your H700 into pairing mode when searching for the bluetooth H700.
It might be a good idea to book mark the main page.
Good Luck! Take your time.
Mike
Apr 04, 2008 | Motorola Mobility H700 Wireless Headset
H700 will pair, but won't connect.
To successfully pair the Motorola 700 with the Centro:
Select Bluetooth from the Home screen.
Select "On".
Under "Visibility", select "Visible".
Now click "Setup Devices".
Click "Hands-free Setup"
On the Motorola earpiece, with the flip-out mouthpiece in the closed position, press and hold the multi button until ring around it glows purple. Flip open the mouthpiece.
Now click "Next" on the Centro's screen.
The Centro should find the Motorola. Hold the Motorola to the right side of the phone if you have difficulty getting the Centro to find it.
Once found, click the Motorola H700 listed in the window and click "OK".
The Centro will ask for the device password. Enter 0000. Be sure that the checkbox for "Add to trusted device list" is checked. Click OK.
The two devices should now be paired to work together and the Motorola's multi button should rapidly blink blue; NOW click "Done".
You will be taken to the Trusted Devices screen.
You will see your Motorola in the list of Trusted Devices. Click on it to highlight it, if it is not already highlighted.
Click the menu drop-down key (located to the right of the ALT key).
You will now see a drop-down at the top of the screen that says "Connect". Click the "palm" center button on your Centro.
NOW the two devices are connected. The phone name will now be bold, and a small Bluetooth icon will appear to the right of it.
When you click the Phone key on your Centro, you will see a tiny blue headphone symbol now at the top right of the screen where the Bluetooth icon used to be.
To use the earpiece:
Flip it open and hang it on your ear.
Dial the number you want to call on the phone.
Press the multi button once and now you should be connected via the earpiece.
To receive a call, when your Centro rings, press the multi button once.
It took me a few hours to figure it out. Hopefully you can do it in a few seconds.
Dec 28, 2007 | Motorola Mobility H700 Wireless Headset
N95 blue tooth pairing
remote sim (off)
That should be ON
Dec 14, 2007 | Nokia N95 Cellular Phone
Motorola H700 Bluetooth Headset
I have a sprint mogul and i do not have the passcode to the motorola h700 do any body have it
Nov 20, 2007 | Motorola Mobility H700 Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Nokia N95 Cellular Phone Logo
136 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
