Question about Hotpoint Aquarius WMA42 Front Load Washer
HI NEED TO REPLACE belt on a hotpoint wf530 is there a simple solution such as adjustor to move motor?
    Genius:
  • Hotpoint Master
  • 1,466 Answers
It is quite a tight fit this belt, No adjustment just sheer power/ I use a wooden peg to assist me ...Watch you fingers! Good luck
Posted on Sep 29, 2009
Hotpoint aquarius WF530 machine
Hi- think I've answered on your other posting ;-0) John C
Oct 15, 2011 | Hotpoint Washing Machines
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
Replace belt on Hotpoint Aquarius WM31 washing
Hi.
Remove top cover of washer.
Remove rear access panel.
Slacken off the motor fixing bolts, and pull motor towards drum top.
Fit belt round motor pulley first, and then feed it round the drum pulley from the rear of the washer.
Tighten motor bolts just enough to hold motor steady, and pull motor towardsa cabinet side to tension belt, it needs to be farly tight.
Then tighten motor bolts securely.
Fit back top and rear covers.
Apr 05, 2010 | Hotpoint Washing Machines
Am trying to replace the belt on a hotpoint aquarius wf240 washing machine. I have removed the 2 bolts which appear to hold the motor in place ( 1 bolt on each side). However the motor still will not
Hi. The motor is non adjustable on this washer. Tilt washer forward, get someone to hold it steady, and put belt round motor pulley first, then slip belt on drum pulley, and slowly turn drum by hand, feeding the belt on as you turn drum, be careful not to trap fingers, as it is very tight, this is normal, as the belt is a stretch type, this is the reason the motor is non adjustable. Please rate my advice. Thanks.
May 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Thanks.
May 27, 2009 | Hotpoint Aquarius WF000 Front Load Washer
How to remove top on hotpoint 473e dryer , a need to change the drive belt
top should pop off use screw driver to pry apart there are 2 clips on the corner then lid should lift up
Feb 20, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Need to replace a door seal on an hotpoint WF530 washing machine?
Thank you for your e-mail, for a donation of €50 I will send you the details on how to resolve the problem.
Regards,
mcgowanj
Aug 29, 2008 | Hotpoint Washing Machines
Hotpoint WMA32 Front Load... Problem:
if its not your belt its the brushes in the motor that need replaced i would replace the brushes first the cost about £15-20
Jan 04, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint washing machine belt come off
u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
Dec 29, 2007 | Hotpoint First Edition FEW12 Front Load...
Hotpoint Aquarius WF530 LEDs flashing
I cannot tell from your description what the error may be but here is a list of reasons;
https://www.whitegoodshelp.co.uk/hotpoint-aquarius-lights-flashing
Jun 13, 2017 | Hotpoint Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
159 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
