Question about Shure 515SBG18X Professional Microphone
I have removed the push to talk button and replaced it with a volume pot but need a wiring diag. from the element to the pot to the XLR. Also, is it possible to wire this to convert it to high impedance? Many thanks.
  • Shure Master
  • 5,603 Answers
The impedance of these mics is around 180 ohms which means you would probably use a pot around 300 to 600 ohms and with an audio taper.
This is NOT a good plan from an engineering standpoint as adding impedance to the balanced mic can allow electrical noise pickup.
The only way to get high impedance is by use of a transformer or a preamplifier. You DON NOT want to run high impedance lines over any distance as they are more subject to noise pickup.
The transformer should be at the far end of the cable run from the microphone. KEEP the impeedance of the cable from the mic LOW until right before a high impedance input amplifier.
Posted on Sep 30, 2009
HOW TO REMOVE THE MAIN HEATING ELEMENT ON A FARBERWARE PERCOLATOR
There is a nut on the inside of the pot that can be removed with a socket wrench. You will also need to remove the bottom of the pot to access the heating element. Remove the wire leads and it should come off.
Apr 26, 2014 | Coffee Makers & Espresso Machines
My spd s has a bussing soud...I have change the cable and still the same problem
I was using a 25 foot 1/4" to XLR cable from the back of the Roland directly into the Thump. As mentioned, I tried going from the Roland to a direct box with a 1/4 cable on both ends; then out from the direct box "thru"-1/4 fitting, to the XLR connection in the Mackie Thump, with a cable that had the 1/4 on one end and the XLR on the other. Still buzzing. So for grins, I hooked an XLR to XLR cable from the Direct Box Low-Z out, to the Mackie Thump, keeping the 1/4 plug going from the Roland to the Direct box and eliminating the "thru" connection from the direct box to the Thunp, (1/4 to xlr). NO BUZZ.
There is a definite loss of signal strength, ie: everything is coming through quieter, but I can raise the volume of the Thump to FULL, with no buzz, and I can raise the volume of the Roland Module to full, and still no buzz. But there is a definite loss of overall volume, I think because I am not using the direct box properly. Hmmmm. As I understand the Direct box, the IN and THRU are supposed to be used as I was, going from the Roland module to the IN, then from the THRU to the speaker. The Low-Z outs are supposed to carry a signal to a mixer, I suppose to use a FOH PA system, or for recording purposes. Still, I have no buzz. Now...........
In looking over the cords, I suddenly realized that the 25' 1/4" to XLR could be the problem. The 1/4" plug is STEREO! Not mono. Could this be the cause of my buzz? I'm thinking I have a stereo plug, so 2 wires are involved, yet I'm using it in a mono imput in the roland. Perhaps this is creating my ground loop?
After getting a 1/4" MONO to XLR adaptor, attach it to my XLR to XLR cord, go from the back of the Roland (1/4") to the speaker directly (XLR) and see if my buzz is still gone.
The problem now becomes going from the Direct box to the speaker, since it needs to be 1/4 mono from the box, and xlr male to the speaker. I cannot locate a cable like that! So, I guess the next best solution is to get an adaptor to convert one end of the xlr/xlr cable to a 1/4 mono plug. At that point I don't think the cable would still be considered a 'balanced' line though, since it goes from 3 wire at the xlr to 2 wire at the 1/4 ts plug, right? The only other solution is to continue running out of the direct box as I am, using the Low-z out xlr connection, so I can continue to use the xlr/xlr cable.
Also there was a button on the direct box, called a PAD, for -15dB, I assume that what was causing my signal attenuation. When I pushed it in and it released, I suddenly had my volume back.
May 08, 2012 | Roland Spd-S Sampling Percussion Pad...
I am trying to replace a master volume pot from a Line 6 Spider 111 30 practice guitar amplifier and cannot get to the circiutry to identify the pot for replacement?
Typically all the knobs have to come off... the nuts on all the jacks have to go... Sometimes there are small screws through the front that have to be removed... some of these are found around XLR type connectors.
Mar 22, 2011 | Line 6 Spider Iii 30
On my squier strat the volume doesnt come out through theamp at all[i know it's not the amp or cable cuz i've hooked others things up to it to make sure]. Everytime i push and hold the volume knob at 10...
It is not clear if the volume knob you are talking about is in the amp or the guitar... SINCE you said you verified the amp is OK I have to assume the volume control you are talking about is in the guitar and my answer is based on that...
I SUSPECT that the resistance element and/or the wiper in the volume pot is damaged. One other possibility is the soldering of a wire to the volume pot may be bad. If you are competent with a soldering iron you could replace the pot yourself or take it to a competent guitar shop for repair. I would myself suggest you open the electronics and look for anything obviously wrong. I have ALSO seen one other problem where one lead of a pot is touching the CONDUCTIVE paint in the cavity where the controls are. If the shaft nut becomes loose and the pot slightly rotates this can happen, grounding out the signal.
Jan 07, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I have the LR baggs Element Active VTC in my Seagull. It works fine, except when I plug it into the PA system at church. There is a windy, rumbling-type sound that happens whenever the volume knob is...
In the first place you CANNOT connect your guitar directely to the snake ! You must use a DI box to convert the unbalanced output of the Baggs to balanced (differential) drive to the snake using either XLR or TRS cable. The DI should be driven as a HIGH impedance in and using "ground lift".
If the pots are noisy, lube sparingly with CRC 226 available in the electrical dept of Home Depot in a spray can with spout for about $2.70. Spray using the spout into the side where the leads go into the pot.
The volume pot is overly sensitive because you are overdriving the mixer at the other end. The trim on that channel of the mixer probably has to be reduced as well.
Dec 23, 2010 | L R Baggs Eas Element Active Acoustic...
Occaisional Loud spurts of noise?? Playing along normally and it suddenly goes very loud for a second. Any suggestions?
This is PROBABLY due to a bad volume control pot or wiring to the pot. Sometimes people have used DeOxit or Blue shower in the pots and it wrecks them. The resistance element may be cracked in he pot. The break would be on the side of the pot that connects to ground.
Oct 31, 2010 | Fender Hot Rod Deluxe Guitar Combo...
The wiring is messed up the volume knob does not work right
If nobody has changed the wiring in this guitar, suspect either a broken wire or possibly a cracked resistance element in the volume pot. This can happen if the knob on it takes a blow.
Aug 28, 2010 | Dean Vendetta XM Electric Guitar
My 2006 Bunn blows a fuse when used
This sounds like a short in the main heating element. If you are within your 3 year warranty, Phone Bunn and talk to their warranty department. They will give you a RMA number and give you further instructions. If not, there are no replacement parts available for these brewers.
Sep 29, 2008 | Bunn NHB Coffee Maker
Water Level
my first response would be to say that you need to put 8 oz. less water in - but that's the obvious and somewhat comical solution. But here's what you need to do:
Take the top cover off (1 std. screw on top) and pull the brown water tray out. turn the unit on its side and clean the heating elements! You most likely have huge calcium deposits in the water tank. Scrape the elements but be careful not to bend the thin wires leading out of the tank (they're paperclip thin and will break if bent back and forth.
After cleaning the elements and tank, remove the drip spout (turn counter clockwise to unscrew) and clean, then clean the red tube hose in the center by pushing a wire (coat hangar thick) down through the middle.
Reassemble and pour two, almost full, pots of water into the tank, this is the default level needed to start brewing. When you pour your third pot in, that is the amount of coffee you will get minus whatever your filter soaks up. Hope this helps - good luck!
F5Tornado
Jul 10, 2008 | Brewmatic Diplomat VI Coffee Maker
Shure 515SBG18X Professional Microphone Logo
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
