Question about Baumatic BT2780SS Electric Kitchen Range
How do I access electrical control switches at LHS of fascia on Baumatic 90cm dual fuel cooking theatre? Main mode switch frequently trips house circuit breakers when rotating from mode to mode. I can remove knobs but can't see how to remove fascia or perhaps the entire hob top need lifting (can't see any fixings though. Assuming I can access switches it still remains to be seen what is causing tripping of breakers - It happens most if switch is rotated quickly - if I pause at each position briefly before rotating further it is less likely to happen Model is BT2950 help???
  • riversidesys Sep 29, 2009
    problem occurs freqently and is blowing the house main breaker, not the cooker circuit
  • riversidesys Oct 01, 2009
    this looks like very sensible advice and gives me a way forward - thank you
    President:
  • 1,653 Answers
You need to be at the rear of the range and remove the right hand panel(s) and then you will be able to access the controls over the top of the large oven cavity. Check for any wiring chafing or any contacts making contact with the chassis.
USEFUL TIP Make sure you have a torch and take a digital photo or two of the wiring as seen above the oven before starting work just to make sure that if you do end up with a stray wire then you know where it belongs.
Posted on Sep 29, 2009
  • 615 Answers
Hi, The manual location and free is : http://files.baumatic.com/usermanuals-uk/bt2950.pdf
You may have an open circuit somewhere and taking out all parts that may not work, first it sound as it does not occur often and for that I think it may not be an issue with the unit but rather with the size of the breaker. If the unit works, good then do the following: start the unit one by one making sure that you have nothing in the house on tell the conclusion of this test. When you come to the one that keep tripping the breaker then this is the one you need to check. If not you may need to increase the Amp as you know each house is different from another and one house may have good wiring and another has the same but bad wiring.
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Oven works but after it has been cooking for a period it shuts the Electrical Safety Switch off. Restart & it just keeps happening.
Well it may be the breaker that the oven is connected to, overheating the switch and tripping it. Try replacing the breaker switch (main breaker box in the house rv) is the best thing, but you can place a small fan from say a old computer or laptop conected to a old cellphone charger, there both dc powered. Just make sure that when you fix it to the breaker switch you leave plenty of room for the switch to trip if it has to ' to avoid house fires'. I had to do this one year because the heater I plugged in was over loading my breaker and had to Jerry rig a old computer processor fan to keep it cool while heating that area of my house
Sep 02, 2016 | In Microwave Ovens
I am having difficulty setting the clock on my Baumatic BAF9006 90cm dual fuel cooking theatre can you please help
HELLO.
Setting your microwave clock is explained below.
It is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be put off.
  1. Touch Clock.
  2. Touch the number pads to set the time of day.
  3. Touch Clock or Start.
Thanks.
Sep 21, 2011 | Microwave Ovens
Hot plate just wont turn on...switches checked in meter box and no iscolating switch. baumatic ceramic cook top. BA 13.2 ( i think) house just been sold. Hotplate wked thurs. House sold Fri. new owner...
Hello, is this a two electrical filament hot plate? Also, is this range stove/oven? I'm a little confused here on what exactly what you are referring to hot plate or cook stove with electrical burners and oven. If it a really old hot plate with one burner look at the plug there could be a fuse in it. If it is electrical range then check the control board and see they a fuse on. If not, check the voltage with a volt meter. Be very careful here there two phase that is 240 Volts AC. The voltage will be split between the two l20 hot legs AC which is 120 degrees out of phase in respect to each other; in other words, don't both of them don't let them touch each other.
If it a kitchen stove I'm fairly sure that the control board is shot and with this not operating it will not open the current/voltage relays for the electrical burners. REMEMBER YOU ARE DEALING WITH 240 VOLT AC...BE CAREFUL.... GB....stewbison
Aug 26, 2011 | Baumatic Microwave Ovens
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
How do you replace headlamp bulbs on 1999 chrysler 300
You half to remove the Headlamp housing to change it. Here is the instructions out of the factory manual.
Tell me if this works for you?
HEADLAMP HOUSING - CONCORDE/LHS/330M Headlamp lens fogging is a normal condition and does not require service unless excessive or continual. Moisture will vent from tubes or vents located on the back of the lamp.
REMOVAL
  1. Release hood latch and open hood.
  2. Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners Access Rubber Grommet
  3. Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield Fastener Locations
  4. Remove the push pins attaching the fascia to the upper radiator closure panel Remove Push In Fasteners
  5. Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s) Headlamp Jackscrews
  6. Roll fascia forward to clear way for headlamp housing removal Roll Fascia Forward
  7. Disconnect wire connector from back of lamp socket(s) and/or bulbs.
  8. Remove headlamp housing Remove Headlamp Housing
INSTALLATION CAUTION: Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
  1. Place headlamp housing into position.
  2. Connect wire connector to lamp socket(s) and/or bulbs.
  3. Verify headlamp and signal lamp operation.
  4. Install jackscrews to attach headlamp housing to crossmember.
  5. Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
  6. Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
  7. Install nut on fascia stud through the splash shield access hole.
  8. Verify headlamp operation and alignment
Mar 27, 2009 | 1999 Chrysler 300M
Baumatic BT187ss Oven All working EXCEPT fan assisted cooking
I have a similar problem with my Zanussi and discovered there is a seperate element arounfd the fan wihich I think may be burnt out. Could be a similar fault have you investigated behind the panels in side the oven?
Mar 08, 2009 | Baumatic B180 Electric Single Oven
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Baumatic BT2780SS Electric Kitchen Range Logo
70 people viewed this question
Top Baumatic Kitchen Ranges Experts
Greg Cann
Greg Cann
Vitaliy Gins
Vitaliy Gins
Treefrog15
Treefrog15
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
