Question about Tomtom ONE GPS Receiver
My tomtom has had no satellite coverage for four hours. i am in Johannesburg
    Brigadier General:
  • 4,090 Answers
Doesnt matter where you are It does not take 4hrs to lock on.
I suggest you recharge your battery to full capacity and then try.
If you have plugged it into the car power and ever started the engine you have damaged the SIIRF chip which means a new mothyerboard will be needed. Expensive!!
Posted on Sep 29, 2009
Are there any greyhound busses from johannesburg to Maputo. I would like to travel to Maputo on 22 September and come back on 26 September
If you want to travel from Johannesburg to Maputo, you have several options; you can fly to ... 150) or bus InterCape (8¾ hours, R 468) or bus Greyhound ZA (8¾ hours, R 375) or bus Citiliner (9¾ hours, ...
Jul 19, 2016 | Cars & Trucks
Tom Tom 540 can't find satellite signal for past hour
The problem can be fixed by resetting the tomtom one xl gps receiver. Tomtom one xl gps receiver is common with this problem, after resetting it, it is most likely it will happen again. So be ready to keep resetting over time.
It most like is as a result of bad strength to search and detect the satellite. So you have to adjust the antenna also to a area where it can pick signals easily. This is quite uneasy because the areas to locate the satellite varies in terms of the location you are.
Software update will not fix this problem as well as the quickgpsfix, so the bes solution is for you to keep resetting it. Hope this helped. Thank you for using fixya.
Jan 20, 2011 | Tomtom GPS
Unable to acquire satellites
GPS devices do not work inside buildings or in tunnels. Even outside, high-rise buildings or trees can interfere with GPS signal reception. Car navigation systems do not work through the roof of the car, they need to be mounted to the windshield of the car with free view to the sky, or use an external antenna.
Some cars have metal coating on the windows for sunlight blocking or privacy protection. Such coatings may also block the GPS satellite signals.
Another problem: unlike TV satellites, GPS satellites do not have a fixed position relative to the ground, they move all the time. Your GPS device needs to locate and tune in on four satellites minimum first to start working for you. The scanning of the hemisphere to locate satellites takes several minutes (up to ten on Tomtom devices).
Tomtom devices use a device stored file with precomputed satellite positions to speed up the process to a few seconds. Since the file holds data only for about two weeks, the package "QuickGPSFix" needs to be updated at least once in a fortnight using the Tomtom HOME software, or it will fall back to the slow scanning procedure.
If you do have a different brand of GPS device, please add a comment to this post and I'll try to give further advice.
Jan 06, 2011 | GPS
Will not link to satellites
1) Install "TomTom Home" software in your computer from www.tomtom.com
2) Start TomTom Home in your computer
3) Plug in the GPS dock to your computer's USB port and place the GPS on the dock. The green light on the bottom right of the GPS should turn ON to indicate that the GPS is getting power from the dock and charging
4) Start your GPS while being in the dock. If the GPS asks "do you want to connect to computer" answer "YES"
5) The TomTom Home software will detect the GPS and check if there are any updates for it. Then you'll be offered updates to install. Some are free, some are not. Install the "QuickFix".
6) After the download is complete, choose "DEVICE" from the TomTom Home drop down menu and choose "DISCONNECT DEVICE". Wait a few seconds until the computer tells you that "NOW YOU CAN SAFELY DISCONNECT YOUR TOMTOM".
7) Turn off your GPS and let it charge for at least 1 hour.
8) Turn the TomTom ON and move it close to a window. Leave it on for at least 15 minutes. It should be able to get a lock on the GPS satellites, even if it is indoors (assuming you don't live in the middle of a city, surrounded by tall buildings)
Please, report back if you need further assistance
My ID: alexocuello_
Mar 20, 2010 | Tomtom ONE GPS Receiver
No satellite signal on TomTom
hi save all the maps and info you have to your computer and then wipe/reformat your tom tom and the reload it and update it and you should be right to go. cheers
ps update as often as possible i update mine 2-3 times a week if using it daily.
Oct 02, 2009 | Tomtom ONE 3rd Edition GPS
TomTom One 3rd edition was working fine for hundreds of miles, then it just started tell me to make strange directions in the middle of an interstate. It then lost satellites. Would come back and give...
The problem may be caused by a lose of satellite coverage. This is a bug that is caused when the GPS can not access satellite for a long period of time. To avoid this you will need to keep the GPS up-to-date by connecting to your computer and download updates using TomTom Home
Jul 11, 2009 | Tomtom ONE 3rd Edition GPS
Can't find satellites
Similar problems happen to mine, but they seem to fix themselves after a while.  I've noticed that in certain areas, it will "crash," for lack of a better word, like yours, and I have to drive to a new area for it to fix itself and to locate the satellite.  I would drive to an area where you know you have always been able to access the satellite, and keep it on for a good bit of time and see if it finds the satellite.
May 26, 2009 | Tomtom ONE v4 Car GPS Receiver
Password
Problem solved. I removed the memory card and reset the tomtom replaced the card and presto it accepted the password . Imust admit that Idid doubt whether I put in the wrong numbers as Im in my late seventies and do have senior moments Thanks for your advice to contact tomtom support but that proved very difficult to access .
Jun 11, 2008 | Audio Players & Recorders
TomTom One GPS fault
I would send it back to tomtom again and tell them it is definatly not finding satellites. Hopefully they will find the fault this time. if you prefer not to send it to tomtom but have it checked somewhere else , then maybe you can search online with google as I know there are at least 3 places to have it looked at but I won't mention them here as its not a forum for advertising. There are several reasons why its not picking up sats but there are 3 most likely causes. A/ Contact with top antenna board has become broken / unplugged ~ tomtom one and one V2. - B/ Ribbon cable has become unplugged ~ tomtom Go - C/ software faulty or faulty sd card . ......... Most likely cause is faulty file on SD card .
Feb 06, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom ONE GPS Receiver Logo
132 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
