Question about Dell Computers & Internet
Our pc went down a while back Dell rebooted I guess you could say but since then we have no cd/dvd burner use on it. How can I repair this?
  • 90 Answers
Well it will be difficult try to get a cd/dvd from somewhere....or do u have a usb device....u can boot from usb u no........u need to fix your bios for boot from usb first
Posted on Sep 29, 2009
Dell Dimension E510 dvd writer does not recognize blank dvd
Try going to device manager and uninstalling the device, reboot the machine and let it reinstall the drivers. Sometimes the driver files gets corrupted and this will resolve the issue.
Feb 22, 2011 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
MY CDRW DELL DIMENSION 5150 BURNER ISNT
im not sure what cdrw isnt doing so i will have to guess
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rw/dvd rom burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 20, 2011 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
My PC is an IDE. the dvd/cd burner went bad. I baught this new LG burner today with an IDE to SATA adapter with the needed cables. I installed it all and it wont even come on, not working. So I am guessing...
It is not the dvd driver problem but more likely to have the adapter issue. The generic Microsoft cd/dvd dirver should be fine, I never have to install and driver for the replacement DVD/CD drive on any of my repair works.
Did you try this setup with another PC?
http://www.cooldrives.com/satoidecofor.html
Jan 01, 2011 | Computers & Internet
My dvd rom on my Dell Inspiron 2200 is not working properly
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 14, 2010 | Dell Inspiron 2200 CD-RW/DVD Drive Combo -...
Hello, just installed (improperly) a H.L DATA storage LG DVD into my dell, the wires didn't match up so I guessed?, does not open?
Dear Dan,
This sounds like an Eye Dee 10 Tee error to me. you guessed..lol.
I GUESS you need to see a computer repair tech.
Nov 24, 2009 | LG 22x8x22x DVD?±RW DL IDE Drive Black...
Recently purchased a dell laptop,it will not let me burn a dvd,i have reinstalled the disk, still nothing, burning software is roxio creator DE 10.2 Cheers, shabell9 sharon_belleville@yahoo.com.au
Are you using the correct CD? and the setting correct?if the laptop new it may be the driver conflicting...go to device manager and go and delete all the drivers that you do not know and reboot the computer after shutting it down and when starting the computer will scan for all installed drivers and reassin them again...let me know if that help and please do not forget to rate this service to be able to improve on it
Sep 25, 2009 | LG GSA 4163B DVD±RW Dual Layer Burner
DVD-RW burn drive is being recognized as CD-rom drive; it's not the laser, because I went through the trouble of purchasing a brand new DVD burner drive and it's doing the same exact thing. Can anybody...
If you have not done so, under device manager, remove the dvd rom (cd-rom) from the hardware list, Use the CD install disk that come with your DVD-ROM, install the drivers and software, then reboot your pc and let it install the new hardware detected. This should get you going.
Good Luck
C2Solutions
Aug 18, 2009 | Computers & Internet
Pc freezes when I click open on my nec nr 7900a cd-rw. dell pc, software windown xp,
this is most likely an interface issue either on the motherboard or drive....could be software but dvd drives don't last forever. when booting press delete and let it go into bios setup. You don't need to change anything in bios, just try opening the drive. If it opens without delay remove any disc. Reboot PC and see if the drive behaves, If it's still being awkward, with the PC unplugged open up the PC and remove the drives data cable. Start PC, close down PC. Reconnect drive (use a different IDE /SATA connection if possible) Try DVD drive again. If the fault still persists, It's most likely the drive. Get a new one they are really cheap.
Aug 02, 2009 | NEC NR 7900A (NR7900) CD-RW Burner
Dell Lat. D600 will not read cd and does not recognize cd
this tool will fix it
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 30, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Computers & Internet Logo
56 people viewed this question
Alun Cox
