Question about Intel DG965WH Motherboard
Will not boot no lights no sound - has been working for the ls 18 months
  • pat1923 Sep 29, 2009
    Power to board seems ok as there is a green light on the m/b
  • 138 Answers
Can u recheck the power connections,, might be mains power not getting,, or loose connections..
Posted on Sep 29, 2009
How do i fix this device sound system for Lexus ls 460 2008 sound system
PDF]Audio system (with the Lexus Display Audio system)
drivers.lexus.com/t3Portal/document/om/.../pdf/sec_03_03.pdf
Lexusbeing used inside or close to the vehicle while the audio system is operating. CAUTION ... Press the "RADIO" button or "AUDIO" button on the Lexus Display Audio controller ..... This device complies with RSS-310 of Industry Canada. Operation .... 460. 3-3. Using the Lexus Display Audio system. ?MP3 and WMA playback.
[PDF]AUDIO/VIDEO SYSTEM
drivers.lexus.com/t3Portal/document/omnav/.../pdf/audio.pdf
Lexus2007 LS460L/LS460 Navigation from Aug. ... system. Your audio/video system works when the engine switch is in the "ACC" or "IG-ON" ... erate this device.
LS 460 Factory Streaming Audio - Club Lexus Forums
www.clublexus.com/.../ls.../622096-ls-460-factory-streaming-audio.html
Mar 5, 2012 - LS 460 Factory Streaming Audio LS - 4th Gen (2007-present) ... Yep, with the new 6th gen nav system Bluetooth streaming is available which ... It is connected to you aux in on the car and your iPhone or other blue tooth device pairs with it. .... How do I fix that? 2008 Obsidian Lexus LS460 - Black MACgic Adding Bluetooth Stereo (A2DP)
Jul 11, 2015
Mark Levinson audio settings...
Dec 19, 2012
Problems Pairing Bluetooth
Jan 7, 2012
Mark Levinson vs. LS460 stock audio system
Jun 18, 2010
More results from www.clublexus.com
Dec 21, 2015 | Audio Players & Recorders
Dash lights quit working on 2000 model chevy LS pickup in okc, ok
sounds like correosion .. pull your fuses clean and replace see if this helps.. if you find relays do the same..post a comment and let us know what happens..
Aug 19, 2014 | Cars & Trucks
My driver side seat is not heating, The 3 little lights come on for about a minute or two then goes out. The seats were working a month ago. Its a 2006 LS Lincoln, the passenger side works fine. Do you...
Both of the front seat heaters run off of the same 2 fuses, so the problem is not a fuse if the passenger seat is working. Each seat has a separate electronic control module, so a bad driver's seat module could be the problem. The seatalso has 2 elements - onefor the seat cushion and one for the seat back. If one is heating and the other is not, then the problem is probably a failed element. If neither element is heating, then the moduleis most likely at fault. The modules in the seats are controlled by the Body Control module (BCM), so the problem could also be a fault in the class2 data circuit between the BCM and the driver's seat module.
In any case, a scan of your BCM will probably yield a fault code that will lead you in the right direction.
Dec 04, 2010 | 2006 Lincoln LS
2006 f 150 axle code b6 what ratio is that
This was current for the 2004 MY, so should work for at least the 04-08 MY range,
Axle Codes (LS=Limited Slip / Traction Lok):
F-150:
19 - 3.55 Non-LS
18 - 3.08 Non-LS
H9 - 3.55 LS
B6 - 3.73 LS
F-250:
27 - 3.31 Non-LS
26 - 3.73 Non-LS
Ranger:
84 - 3.45 Non-LS
86 - 3.73 Non-LS
87 - 4.10 Non-LS
89 - 4.56 Non-LS
F6 - 3.73 LS
F7 - 4.10 LS
92 - 3.08 Non-LS
R5 - 3.55 LS
91 - 3.27 Non-LS
96 - 3.73 Non-LS
R6 - 3.73 LS
Nov 10, 2010 | 2006 Ford F-150
My sound driver is not working properly.After reinstalling windows xp sp3(clean install),i couldn't hear the sound.The device Manager is showing Multemedia and Audio controller and could insatll the driver...
Go to the web site of what ever PC you have ( Dell, HP or what ever the PC is ). At the web site you should find section that says drivers and support, or something like that. It will have you select your make and model. You should find the correct drivers there.
Hope this helps.
Good Luck
cookEmonster
Oct 17, 2010 | Intel Computers & Internet
Service light is on my whirlpool washing machine and won't allow the wash to start, can I override this as it's only 18 months old?
The main motor in the whirlpool front loaders has brushes. These will wear out eventually. Does the drum try and turn when a load is started? If not the motor deserves a check. 18 months sounds short but possible. Mine took 4 years to wear down.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Nikon LS 2000 hardware problem
Here's what you need to do (carefully!!):
www.vad1.com/photo/dirty-scanner/ls2000-cleaning/
Dec 08, 2007 | Nikon LS 2000 Film Scanner
Intel DG965WH Motherboard Logo
881 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
