Question about Hotpoint RLA50 Refrigerator
Water appearing on fridge floor because of blocked drainage hole
Why is this happening every 3 weeks, it cleaned out every 3 weeks after the previous leak and still does it again ?
  • 142 Answers
Clean out the drain hole with a thin flat bladed s/driver then pour some water down the hole so you no you have cleared it.
Posted on Sep 29, 2009
Testimonial: "Will give your solution a try, fingers crossed. "
My french door freezer side water is dripping collect in the bottom of the freezer. its frozen solid and then melts and drips out the front of freezer onto the floor making a puddle of water
Your drainage hole is blocked.. empty the bottom half of the fridge and freezer .. you will see a V shaped moulding in the back panel INSIDE each compartment.. smack bag in the middle is a hole that allows the condensate to run away, but sometimes a pea or other obstruction clogs it, so the water cannot run away, but is held back.. where it refreezes, blocking the tube further, and causing the next cycle to run the water into the bottom of the appliance, where it refreezes.. but later thaws and floods.... I suggest you pull out the appliance so you can check the drainage tube(s) by eye.. use a chopstick, and if you can find a cheap shop selling 'bottle brushes' about the width of your little finger, push that up and down it a few times to properly clean it..
Apr 24, 2017 | Refrigerators
Water leaking with icing formation below veg tray. can see flow of water from middle section of the refrigerator,water flowing out of the refrigirator.Model no-RT60KZRIH1
Frost free fridges will periodically allow frost build up to melt and run down the back of the fridge to a small hole which leads the water out and on to the compressor behind the fridge. The water is then evaporated by the heat of the compressor. The hole can get blocked and this leads to the water overflowing and running down to the bottom of the fridge. Clean out the drainage hole regularly.
Jan 30, 2015 | Refrigerators
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
We have a hotpoint RLA 34 ( MICROBAN ) FRIDGE . water keeps seeping into the bottom , under the crisper box tried turnining temp down , made sure it's level , no blocked drainage hole . door shuts tight...
You said no blocked drainage hole, where was the drainage hole that you checked located? Did you pour water down this drain, and furthermore did you check that the water you poured into the drain flowed into the condensate pan on the outside of the fridge? Unless you have a problem with an ice maker leaking water, it sounds very much like you do have a blocked drainage hole, otherwise known as a defrost drain. the drain system begins underneath the evaporator coil inside the freezer, this is where the water that is collected in the defrost cycle flows into a drain tube that leads the water down to the condensate pan. The best and safest way to clear out this drain is to blow it out with compressed air, after you remove any and all ice at the beginning of the drainage system, in other words, the hole located underneath the evaporator coil.
Nov 09, 2010 | Hotpoint RLA31 Compact Refrigerator
Water in wood's fridge
If you have the wire metal shelf model, there is a wrap around cooling plate (back and two sides) at the top of the inside. The frost that forms on this while it is running melts off after the compressor stops and the water runs down, into the drip channel, and out the drain hole at the center of the channel on the back wall. Clean out that hole so the water will flow out instead of down the walls to the bottom of your refrig.
If you have the glass shelf model, you have to remove the metal cover at the bottom back of the refrig and clean out the defrost drain hole located there.
May 21, 2010 | Refrigerators
My refridgerator leaks water every two weeks
check to make sure the drain pan is in the right place. If it puddles up inside the bottom of the fridge first, your drain hole is plugged up. for this, you wil have to remove the access panel in the back of the freezer side to get to the drain hole. you may also have a crack in your drain pan.
Aug 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Same Problem ...Drain Hole Freezing up.
After facing the same issue (defrosting, cleaning the drain, drain gets blocked again...start again: defrost, etc..) I decided to try to give it one last go:
1. Defrost
2. Clean & rinse the drain (ensure is fully clean and I can pass liquid through the drain).
3. Get a ~30 cm pure copper wire
In my case I took a 3amp power cable, and took the copper wire from one of the cables.
4. Wrap one end of the copper wire around the copper coil at the back of the fridge (where the coil is warmest)
5. Insert the other end of the copper wire in the drain (just above the drip tray). I inserted ~15cm of wire into the drain.
The purpose of these last steps was to ensure there was no "freezing" happening on the drain. The copper effectively will keep the temperature inside the drain above freezing.
Not sure how permanent this might be.. so far at least I'm getting more months than with the previous symptoms treatments ;)
Best of luck!
Jul 09, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Small puddle of water on floor in front of fridge
there is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
May 23, 2009 | Bosch Logixx KDR40423 Refrigerator
Water inside my Hotpoint Fridge/Freezer RFA70
There is a kit available, WR2X9393 which includes an aluminm heat probe which you attach to the heater to prevent icing of the drain
Mar 06, 2009 | Refrigerators
Hotpoint RLA50 Refrigerator Logo
165 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
