Question about Whirlpool Washing Machines
AWM8125/3 WASHING MACHINE HAS FAULT F16 DISPLAYED. WHAT DOES IT MEAN. I JUST MOVED THE MACHINE TO CLEAN FLOOR SO I WONDER IS IT SOMETHING TO DO WITH ITS LEVEL ON THE FLOOR. PLEASE HELP
  • 82 Answers
Hi, I've been double checking the fault codes for you and it seems the 'control unit' is faulty.
Fault code 16 and above point towards a control unit failure.
I'm not sure how moving the machine could have caused it to fail.
Sorry but hope this helps.
I wonder if you switch it off, (un-plug it) confirm you have no kinked hoses and re try it. Worth a go maybe.
Posted on Sep 29, 2009
Testimonial: "Thankyou for that. I switched machine off and on and it worked!! simple as that! Thankyou again "
    President:
  • 1,653 Answers
This means thatthere is a controller board failure and the remedyis to replace the controller board. Thhis could mean that a connector has become disloged by movingthe machine so cheack every connector to make sure it is fitted correctly.
Testimonial: "Thankyou for that. It turns out that once i switched machine off and on again it worked again. Thankyou for your help anyway. M"
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
What does error F:16 indicate?
no one will know without a MAKE and MODEL.
Dec 26, 2015 | Washing Machines
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
What does an OE error msg mean and how do you fix this
something is blocking the pump.unplug first.take drain hose and hold down at floor level with a container to catch water.it may be a coin or a wire from a bra,hair bobble etc feel in the pump to see if the impeller is free to move.if it is then suspect something in the hose between drum and pump like a sock.that restricts flow enough to put up fault code
Aug 04, 2014 | LG WM Washing Machines
My washer won't spin it fills with weather then flashed f16 !!! Help what does this mean
First of all check your hose is clear of any blockage, it also could be something blocking the hoses going to the pump, check the little drawer too (empty it) should be at the bottom of the washing machine, can you hear the pump trying to kick in? as if it's trying to drain? the pump may need replaced for draining the water after the spin cycle, I had the same symptom on my own washing machine, replaced the pump and it's been working fine ever since. You could e-mail the manufacurer too, they can tell you which service error code this F16 is - as I do not know the manufuturer or model of your washing machine as you did not mention then I wouldn't know exactly why this
Mar 31, 2014 | Washing Machines
What do's f16 mean on the bosch classixx 6 1200 mean
F16 is a door fault, could be the door is not tightly closed before pressing start, the lock is faulty so the machine is not registering that it is closed or the wiring connection to the door lock is loose.
Apr 10, 2013 | Bosch Washing Machines
H20 is showing on the display screen of my hotpoint washing machine. I'm aware this means water but I'm wondering why this is displayed?
Possible that there is no INLET pressure or water flow to the machine, check the inlet filter and valve, check for good flow to the valve if the hose is disconnected. If not it needs to be checked if the panel board is showing error due to memory fault..
Jan 23, 2013 | Washing Machines
I have a Bosch Logixx 8 washing machine showing error code 34. What does this mean?
Same as 'F16', 'F34' stands for 'door lock (fault)' ;-0)
This is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 15, 2011 | Bosch Washing Machines
Code f-3
What should I do when the automatic safety system detects a malfunction?
The programme is interrupted, an audible tone sound and various indicators (if available) point to the
source of the fault.
Fault description table
Small lamp lights up Digital display Audible tone Fault description
“Water tap” “H” and “F” 30 sec “Water inlet fault”
- “P” and “F” 30 sec “Draining fault”
- from “F4” to
“F16” 30 sec “Electrical components fault”
“Water Stop” “A” and “F” 30 sec “Water Stop fault”
Jan 17, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
