Question about Kodak Easyshare C813 Digital Camera
My kodak easyshare c813 camera wont work! the batteries are fine becuase ive tested them a lot. and i tried cleaning the batteries and the camera like the suggestion said but nothing! someone helpppp ;(
  • hit_the_floo Sep 29, 2009
    how do you reset the camera settings?
    Genius:
  • Kodak Master
  • 1,099 Answers
We recommend you to use original Kodak batteries, CRV-3 lithium, AA non-rechargeable lithium batteries or
Ni-Mh rechargeable Batteries KAA2HR.
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Posted on Oct 12, 2009
  • 90 Answers
Try to reset the camera setting...
contact your nearest seller
Posted on Sep 29, 2009
My Kodak C813 camera won't turn on. is it the batteries or another problem?
go to a battery plus store....they have batteries for everything and they can test out your camera to see if its the battery and they do not charge...i work there so i know :)
May 05, 2011 | Kodak Easyshare C813 Digital Camera
My kodak easyshare C813 wont tern on i havent used it for a wile help
Are the batteries charged? If no replace. Were batteries left inside while the phone was left idle? Try and scrape the terminals. Try switching it on if it'll work.
Dec 06, 2010 | Kodak Easyshare C813 Digital Camera
My kodak easyshare wont turn on anymore and it worked fine the other week ive tried putting new batteries in it and it still wont turn on i dont kno what to do or how to fix it and its a great camera ive...
Try removing the batteries then either plugging your camera in with the AC adapter or the docking station. Try cleaning the contacts from the battery and the battery compartment of the camera.If your camera works with either one of these then you have a problem with either the batteries or the battery contacts. If your camera doesn't work with the AC adapter then you will have to send the camera in for repair.
Oct 01, 2010 | Kodak EasyShare C180 Digital Camera
Camera will not switch on batteries are new.
I had this problem and it turned out to be the battery contacts, even though everything looked fine and clean.
Open battery compartment and use a dry q-tip to 'polish' unseen oil film off so called gold contacts, then polish the top and bottom of the battery contacts and replace the batteries again. And turn on - if noting try again, but firmly pressing battery cover a bit harder, and see if it will now turn on.
Failing that , repeat with new batteries, but wobble the battery contacts inside the battery well. Cool canberra.
http://www.ifixit.com/Guide/Repair/Installing-Kodak-Easyshare-C813-Logic-Board/2340/8
Jun 22, 2010 | Kodak Easyshare C813 Digital Camera
Wont turn on
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
Dec 31, 2009 | Kodak Easyshare C813 Digital Camera
Kodak EasyShare C813
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 26, 2009 | Kodak Easyshare C813 Digital Camera
My kodak easyshare c813 camera but it wont turn on
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Sep 26, 2009 | Kodak EasyShare P850 Digital Camera
Kodak C813 turns off because of low battery - all of the time!
The way to test this is to have some new batteries of the best grade, don't use the cheaper types, these may not make these cameras work correctly. I have seen this problem before.
Also you can try a set of fully charged rechargeable batteries. These kinds of cameras may use more power and need more power to make them work right.
Links to possible help on this:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=11580&pq-locale=en_US&_requestid=8931
http://selfservice.kodak.com/external/en/urg/urg_00776/GLB_en_urg_00776_manual_ATG/urg00776c3s1.html
Aug 23, 2009 | Kodak Easyshare C813 Digital Camera
My Kodak EasyShare C813 says lens error 111000 evrytime I turn it on. And then it will shut itself off. What is wrong with my camera?
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 31, 2009 | Kodak Easyshare C813 Digital Camera
Turning the light on when taking a video
with kodak easyshare c813 light not available in mode taking video
Dec 27, 2008 | Kodak Easyshare C813 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
224 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
