Question about Canon Rebel XT / EOS 350D Digital Camera
Camera cannot communicate with built in flash. Error 99 is reported, and no shot can be taken when flash photography is required. Camera works normally when flash is not required
SOURCE: Error 99 only when flash pops up
We ended up sending the camera in to Canon. $200 unless they find something more wrong. Luckily we have my Nikon D80 still. I will say that Canon replied via e-mail fairly quickly and one paid, said 7-10 business days for the repair.
Posted on Dec 09, 2007
  • 8 Answers
SOURCE: err 99 on canon rebel xt 350 d
The Err 99 problem occurs due to dirty contacts between the body and the lens. I recommend cleaning the contacts. You can then turn Off the camera and then remove and reinstall the batteries to reset the camera to get the problem fixed.
Posted on Jan 15, 2009
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
  • 80 Answers
SOURCE: Error code 99. Please tellme what this means.
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Posted on Apr 06, 2010
  • 80 Answers
SOURCE: error 99 can't make a shot
this is what the canon people say to do for error 99
Read this!!!
I did this to each of my three lenses just to be sure. Lo and behold, it worked good luck have a nice day!!! :) :) :)
Posted on Apr 08, 2010
My canon EF-S 17-85 IS USM lens will cause an error 99 when in wide angles at 35mm or less. The iris closes but will not open until I "re-boot" the camera. Other lenses work fine on the camera and the...
Zborn, did you find any solutions? I have had same lense for 2-3 years, taken maybe 10000 shots and just yesterday started to get error 99. Spent most of today trouble-shooting to repeat problem and it seems that when I set to less than 35mm I get the error 99. other settings and my other lense has no problems.
Dec 18, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
The flash pops up but doesnt work. than gives me a busy signal than gives me the 99 warning. it was dropped a short distance from my hands. just want to know what i can do myself. if anything
This error is usually assocociated with a dirty lens mount.. rub both lens mount terminals and camera terminals with a pencil eraser making sure nothing gets inside the works. and reassemble.
Other reports indicate it can also be the battery terminals.. do the same thing.
regarding the flash.. if the lens mounts are dirty ( or misaligned requiring repair) the flash will not flash.
Please rate my help++++Thanks for using FIXYA
Nov 19, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Error message communication between camera and lens is faulty
Your flex cable to the Iris is broken. Have a look at my gallery at http://www.pbase.com/barry_2718/efs1785mm I have the same symptoms. At 28 or 35mm it make work ok. try Av mode and f8 aperture to see if you get an err01 because the aperture does not move either. Sound like you may have been sold a dead lens I am afraid to say. There are lots of reports about this lens failing after 2 to 3 years of use.
Aug 16, 2009 | Canon EOS 50D 15.1MP Digital SLR Camera...
Error 99 or 90
err 99 is moisture or dew inside the camera.
Aug 14, 2008 | Bower SFD35C for Canon TTL Flash
Night shots
Hey matty reps,
You are attempting one of the most challenging types of photography there is, because you are combing nighttime photography and action photography. If you want to stop the action you normally would be using the highest shutter speed possible, but since you are trying to take nighttime action photographs I would rely on a flash since the flash duration in essence becomes your shutter speed. I would definitely use a hotshoe mounted flash because the built in flash will most likely not be powerful enough for your needs. I would have the camera set to aperture priority so I could control the depth of field, because the smaller the aperture the larger depth of field you will have and the less likely your subject will be out of focus. If you are attempting natural light nighttime action photography you will definitely need a very fast film speed such as 3200 speed film which will provide significant loss of image quality. You will also need a very fast lens meaning a lens with an aperture of at least f2.8 or larger, and your camera in this scenario should be set to shutter priority so you can set the camera to the fastest shutter speed possible but this will present focusing issues. In both scenarios I would have the AF system set to continuous so the camera doesn't require you to achieve focus to be able to trip the shutter. As in all challenging photography situations more photos are better than less, because you should have more failed photos than successful. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 28, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Error code E:62:20 meaning
This appears to be a problem with a connector inside the camera. Try:
  • Take the memory card out, clean the bay and the memory card with compressed air
  • Take the battery out, clean it and the battery compartment with compressed air.
  • Some users report that you can 'fix' the problem by tapping it gently on the battery compartment, so that may be worth trying as well.
If these things don't work, it will have to taken to a service technician - it's quite expensive to repair, sadly.
Apr 14, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Good book for a beginner?
have you set it to macro mode? (little flower icon on the right cursor) this function will allow you to get within about 2cm of the subject, however do not use the zoom as the lens cannot focus close enough. To get results any closer you will be looking at an slr and a budget on a few thousand! If enabling macro and not using zoom to allow the lens to focus doesn't get you close enough in you can always enlarge and crop images. have a look on www.picture-skew.blogspot.com i've taken some macros of flowers and bugs, this camera can capture the hairs on an ants back or the individual lenses of a flys compound lens eye.
persevere with this camera, for a very small budget you will get amazing results, ISO refers to the speed of 'film', it comes from the dark old ages of 35mm film cameras. Basically a low ISO is the lowest sensitivity to light and gives the best image quality, however as the ccd is less responsive to the light the camera holds the shutter open for longer. The higher the ISO the more sensitive the ccd but the greater the noise and lower the quality of picture.
Books, try looking for more photography orientated books and less digital camera based books. An upto date photography book will tell you all the technical information about how to take a good picture for any given senario.
if you would like any further advice email me (address on the blogspot)
Dec 20, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
D40X flash problems
As the manual warns, never operate the camera (or any device, in general) if you notice something like that. Remove the battery, and send your camera for service
One can only guess what was the source of the problem. Did you drop the camera, expose it to high temperatures (e.g. left it inside a car in 40 degrees Celsius) or expose it to torrential rain?
In any case, how long it will take to repair it (or, more likely, replace it) depends on your local Nikon service department.
Dec 08, 2007 | Nikon D40x Digital Camera
How and when to use the flash
When you take a shot slower than 1/20, the shutter takes longer to close. This means while it is open, it will record everything. The best way to correct this is not the flash really. Try putting it on a tripod. This way you can lower your shutter speed without sacrificing crisp pictures. Also, with a built in flash, you get a very shallow lit area. If your subject is far from the camera, the flash won't do much good. When this happens, the only thing to do is get a stronger mounted flash or slow your shutter down and open up your aperture. Hope this helps. Keep me posted. Photography is a never ending learning process.
Oct 15, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
