Question about Sharp AL-1457 Black and White Copier
The 'replace drum' light on my Sharp AL-1457 copier flashed. I replaced the drum with a new one, AL-100DR, but the light is still flashing and the copier won't work. I've done this before without any problem at around 18,000 copies. It's now at around 36,000. Dud drum? Ruairidh
  • Sharp Master
  • 1,297 Answers
You be must perform the AIDC set(Automatic Image Density Control),and reset the PM(maintenance counter).
Posted on Oct 03, 2009
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
I replaced a new drum cartridge for Sharp AL-1631 Copier, but the warning indicator light is still on and the copier is not working.
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Good Luck and Thank You for using Fixya.
Sep 17, 2010 | Sharp AL-1641CS Color Copier
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
Sharp AL 1010
Hi, to reset drum light follow this sequence: press cancel, exposure, cancel, exposure. Display goes blank, enter 24, print, 07 print, cancel cancel. Cheers
Andy
Jan 25, 2008 | Sharp AL 1215 Black and White Copier
Sharp AL-1457 Black and White Copier Logo
183 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
