Question about NetGear DGN2000-100NAS Router
Cannot seem to get wireless connection . ethernet connection works fine . do i need usb adapter to bring my 3 year old laptop up to N standard ? Ray
  • Banumathi M
    Banumathi M May 11, 2010
    In the netgear smart wizard,under set up menu->wireless settings check whether the channel is 11 and mode is g&b,if not change it andd click on apply.check the adsl settings also.Are you unable to connect the network or to the internet?
    President:
  • 803 Answers
If your laptop does not have a wireless card built into the computer then yes I would go and buy a usb wifi adapter because you cant get wifi if you dont get one.
Posted on Sep 29, 2009
  • 1,272 Answers
If you wish to increase the wireless performance on your 3 yrs laptop then you may purchase N standard adapter like WN111. Otherwise if the wireless adapter on the laptop is working normally then you can still connect to the wireless network using that.
Hope this helps.
  • 138 Answers
If you have your laptop with wifi, then it will connect your router wireless,, if your pc dont have wifi, then you should connect your wifi router with usb adapter,, so that then you can connect other laptop or wifi devices with wireless
Make older blu ray wireless
I would go with a wireless Ethernet adapter not usb. I've used them before for the same purpose It works on bluray player, XBOX 360, DVR system etc basically anything that takes an Ethernet connection to your network.
Sep 20, 2014 | Televison & Video
Apple USB Ethernet suddenly not functional with mac book air
I've run into a similar problem myself. The problem could be that there is another device in the area using the same frequency and is causing interference. Try changing the frequency on your adapter. If you've recently added a wireless device and you can't change the frequency on your adapter try changing the frequency on the new device or turning it off to test if it's the problem.
It's possible someone else in the area has added a device that's causing the problem look around for new wireless devices or antenna in the area.
May 27, 2010 | Apple USB 2.0 Ethernet Adapter for MacBook...
ADAPTER not working
Check the distance bet computer and the Router.
Donot keep your router near television, microwaveoven or any radio active devces, it may reduce the performance.
Check the Antena terminals for any loose connections.
If possible check your wireless signal strength with another Laptop, to diagnose the router is working fine.
If everything seems to be fine, it maybe the issue with the Adapter.
Goog Luck
Feb 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Is there an ethernet cable that will fit into a panasonic cf28 toughbook laptop as i need this in order to get it to go wireless
If there's an ethernet socket on the computer then there's a cable to fit it.
Most computers today have ethernet as standard (the socket and cable have been standard for years).
Why do you have to use the ethernet to connect wirelessly? Normally just activating the wifi in the computer and logging into the router is all that is needed.
Jan 06, 2010 | Panasonic CF-28 (cfwwl281m) Wireless...
Wireless switch on my pc is on but cant connect Work with ethernet cable plugged in.Are there any settings?
Things to try:
1. Plug in the ethernet cable then restart the laptop.
2. Right click on your local area connection and make sure its enabled
3. Make sure your wireless adapter is disabled.
4. Check if you need a static ip address on your work network. and if so have them assign you an ip address for your laptop.
5 Test your computers ethernet port on another wired network to make sure that it is good.
6. Get a usb to ethernet adapter for your laptop if your ethernet port is bad on your laptop.
Sep 11, 2009 | Intel Computers & Internet
When i turn on the new installed printer, no more internet
Hello! I recommend that if you have a second desktop or laptop try to install those devices on it, so you can check if your old PC is the source of the problem or it is one of the devices. I think the most probable reason for this could be a power failure on that old desktop pc, that results on bad management of USB ports
Mar 22, 2017 | HP Pavilion IQ506 22" TouchSmart PC PC...
USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
Nov 26, 2008 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
Can connect with usb stick on one PC and through inbuilt wireless on a laptop to the main router but not a new one
becos of you using three different os one is xp,other one is vista and other on is xpsp3 all the driver is different so how can he connect it.
Sep 06, 2008 | NetGear WG111 802.11g/b Wireless Adapter
When using ethernet connection with wireless router rate is 100 mbps but when I use linksys 2.4 usb wireless adapter ( to get rid of the ehthernet cable lying on the floor)rate is now 54 mbps? Is this the...
By the sounds of it the router is Wireless-G standard. This has a theoretical max speed of 54Mbps. If you wish to increase wireless speeds you would need to upgrade to Wireless-N standard. Do would need to change the wireless in the pc or laptop also. This should give a theoretical max speed of 100Mbps.
Ethernet cable will be cheaper!
Aug 14, 2008 | Computers & Internet
Wireless router needing ethernet connection?
Hi ABVT66 - Didn't your router come with two short cables? It should have. One is the cable that hooks up the modem to your router and the other is the cat5 (ethernet) cable that connects your router to your pc. Let me know if you have these cables. Also, if you check your device manager on your pc, click on the + next to network adapters and it will tell you your network adapter. DON'T RATE THIS 'TIL WE'RE DONE. Thanks.
Jeff
May 22, 2008 | Computers & Internet
NetGear DGN2000-100NAS Router Logo
389 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
