Question about Xerox WorkCentre 220 All-In-One Laser Printer
I have run out of toner but the fax keeps coming in; how do i get to those faxes before I change my toner..
  • 615 Answers
Hi, you still can get to these faxes even if the printer claims that the ink is empty, just keep printing but use the preference of the print o lighter one by using fast draft that way you will be using less ink.
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Posted on Sep 29, 2009
Changed toner cartridge and now keeps stating error...change toner cartirdge
In the menu on the printer have it run a thorough cleaning on the print heads. Should be in the set up menu.
Nov 13, 2014 | Brother PPF-5750E 33.6K bps Super G3 Fax...
When we recieve faxes they have black lines running down the entire length of the page. I have already changed cartridges and am wondering if there is something that needs cleaned? What can I do?
You have to determine if your FAX is the problem or the sending FAX has the problem. The first thing to do is make a copy or print a report. If it comes out clean you FAX is NOT the one with the problem. The sender has to get their optics cleaned.
On the other hand, if it's still "streaky" then your fax has a problem. First off remove the cartridge and look inside it, if you see toner get a can of compressed air (sold in office supply stores to clean keyboards) and blow out as much as you can. I suggest taking the machine outside the toner dust can make quit a mess. Make a few copies (5 - 10) to check it out. Each copy should come out with less misplaced toner.
Dec 07, 2010 | Brother IntelliFax-2820 Laser Fax
I get a white line through but it is not telling me to change toner?
This can occur if you receive a lot of faxes that may have a vertical block or a lot of text or pictures etc. in the same location on the page. The toner can be used in that particular area of the page and a white line results.
Remove the toner cartridge from the fax, keep it horizontal. Shake it side to side whilst keeping the cartridge horizontal. This redistributes the toner inside the cartridge. Replace the toner cartridge in the fax.
Hope this helps.
Feb 09, 2010 | Brother IntelliFax-2820 Laser Fax
Can't dislodge toner cartridge from the drum unit
Sometimes a peice of the cartridge comes or breaks off and jams in the way, it can be a real headache trying to remove. If you search around the lower part you may find a peice hanging down and blocking it. A lot of time you'll need a tech to keep from damaging the printer.
Hope that helps...
Lbcoaster
May 28, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Change toner and it comes up with Toner Life End
Im think you leave the cover open and hold down clear
Jan 21, 2009 | Brother IntelliFax-2820 Laser Fax
Intellifax 2820 plain paper fax
Take it out with the drum unit and make sure the toner is in the drum unit right. If it was ok before you changed the toner then you did something wrong. reinstall the drum and toner after you check it. Lawrence
May 01, 2008 | Brother IntelliFax-2820 Laser Fax
Keep saying change cartridge
Yes i found one spring was out of its place it is near the paper feed assembly.
After placing the spring in its hinges the problem was solved.
Mar 31, 2008 | Canon L220 Plain Paper Laser Fax
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Xerox WorkCentre 220 All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
