Question about Toshiba TN61X81 61" Rear Projection Television
I have a Toshiba rear projection TV with cabinet and I think that the tubes are starting to go,there are black lines each side of the telly. I love my telly and don't want to have to part with it.
  • 1 more comment
  • christinegun Sep 30, 2009
    They are at the left and right of the screen.
  • christinegun Oct 01, 2009
    Just on the right hand side only and along a little bit,but the picture is still nice and clear,many thanks for your advice,its still going to be worth repairing then,how much do you think,this will cost me?
  • Lavell Turner
    Lavell Turner May 11, 2010
    Please describe the lines futher. Are they horizontal or Vertical? Are they on top or bottom?
    Genius:
  • 1,112 Answers
Hello Christinegun:
No your tubes are not going out, Seems your having a horizonal deflection problem, low High voltage, One or maybe two of your HV scan Capacitors are leaky, have a technician check them for discoloration and swelling. If any are have them replaced. Also have him measure the HV at each picture tube to make sure no perticular tube is causing more load then need on the horizontal circuit and check all soldering around the flyback transformer.
Please leave comment if this helps or answers your problem..
Lavell
Posted on Sep 30, 2009
Testimonial: "Well many thanks,no there isn't a black line going down the side of the left hand side of the screen,its just on the right hand side only."
The picture fluxe's apparently are going and not the tubes.Therefore making it cheaper to have it repaired.
Where can I Purchase a new Lamp for my Toshiba Rear Projection tv Model No 52JM9UA, lrenton@bigpond.net.au
Lamps are for DLP TVs, Tubes are in Projection TVs Red/Green/Blue.
Mats has Lamps for $89.00 1-800-628-1118
Tubes cost $450.00 and up Encompass Parts Distribution has service Manual/Parts for this Model
1-800-638-3328
What seems to be the Problem with your TV and what makes you think One of the Tubes is Bad?
Most common problem with this TV is the STK ICs STK392-110. Mats has them.
Jan 09, 2011 | Toshiba TZ50V61 50" Rear Projection...
The bottom 6in. is black no picture
i cleaned the dust, then tapped on the two little black boxes that have like a sparkplug wire going to the tv tube its been 3 weeks and still works fine.
Oct 03, 2009 | Toshiba TZ43V61 43" Rear Projection...
Black lines in tv
Most likely there are electrolytic capacitors in the power supply, video path, and scan amplifiers that are starting to fail from age. This is common in many of these sets. In consideration of the age of the set, this may not be worth having it serviced.
Jerry G.
Sep 24, 2009 | Toshiba 51H93 51" Rear Projection HDTV
Toshiba 50A60 Projection TV - Black Screen
There is no bulb in that model TV. There are 3 crt type tubes. You'll have to have a TV shop determine the cause. It could be many things like no high voltage present, cathode voltage missing. If the tubes are finished, the cost to replace them is quite high. It is a complicated repair since the tubes have to be properly aimed and converged. The repair cost in this worst case scenario would be greater than buying a flat screen TV with the same screen size.
May 17, 2009 | Toshiba 50A60 50" Rear Projection...
Toshiba 57" HDTV no red in picture
I had the 65" version of that TV. Loved it, unfortunately it went bad as well. It sounds like the red tube went bad. The tube itself might sell for $400 plus. The installation will take several hours with the alignments which will need to be done. Then after all that you will start to have to worry about the other tubes starting to deteriorate. If there is any red in the picture then the tube is most likely the problem. At tat point I would say buy a new TV. The best bang for the buck if you want size and have the space for it would be the new Samsung or Mitsubishi DLP's. I just installed one at customers house. The 60" Mitsubishi is 1400 at Best Buy Good Luck Rob
Feb 27, 2009 | Toshiba 57H83 57" Rear Projection HDTV
51" rear projection tv toshiba turning green.
the problem is most likely the crt tubes . There are three.
red green and blue. one of the tubes is bad cost of tubes are around 200.00. plus labor cost is 500.00 if you had it done,
I f you feel mechanical you could do it but it is trickey To start you have to remove back cover look in side you will see the tubes four screws hold them in lots of plugs
to disconnect . If you feel you can do it at least buy looking at it you will know, But before you start first see if tubes are aviable.Call toshiba or try on line first www.part store.com
good luck doctor video please be careful the tube. hold a charge and you could get shocked.
May 18, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Toshiba 50H72 rear projection TV. NO Video
Bad caps and solder connections, especially in around the 9v regulator just about center of the defection circuit... Not a terribly expensive job and certainly worth the repair if the cabinet is in good condition...
Bill
Jan 13, 2008 | Toshiba 50H72 50" Rear Projection...
I think the color tube is shot
Sounds more like the convergance ic's
check these sites out:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 50H72 50" Rear Projection...
Open Questions:
Toshiba TN61X81 61" Rear Projection Television Logo
285 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
